New bike build
  • #61
    A larger front wheel? 21 inch maybe?
    If you shorten the main leaf it’ll bring the front leg back, and may allow you to skip the extra leaf.
    • JD64k
      JD64k commented
      Yea I was thinking that too, it's funny how thing and looks change when it off the table and on the ground.
  • #62
    I don't know how I missed this thread but your skills are amazing. It's impressive to look at the quality work you are doing. That front end is awesome!! Thanks for sharing your progress
    • #63
      Just a small update been real busy my son is back to racing so that has slowed the build a little but I did get the rear sprocket spacer machined to get proper spacing and alignment for the chain
    • #64
      Ok guy's sorry I have been away family things and vacation gets in the way sometimes but I mocked up a new set of bars for the bike that I think looks better,because of the shape and location and the size of the bender die I wanted to use these are actually made in three pieces and still need a little tweeking but I got to stare at them awhile,tell what you think, if you like or don't tell what needs to be changed.
        What brand and model # is the tank you chose?
    • #65
      A little less angle on the grip ends. That's what I don't like about the stock bars, to much wrist angle! JMO. Hope everybody had a good holiday!
      • #66
        What part of the Country are you building this Machine?
        • JD64k
          JD64k commented
          eastern Pa about 30 east of Philly
      • #67
        Yeh! That's what I'm talkin' about! I like that bar. I like a wide bar. I've put one on my bobber, and my two-rider, and I like wider bars. They're just so much more classical.
        • #68
          NCB, Angled which way?
          • #69
            So your wrist is not turned as much. Somewhere between a drag bar and the way you have it now. Never liked the way most stock bars have you turning your wrist out. Maybe because i have wide shoulders, I don't know. Never really heard other people complaining about the wrist angle. would like to have a set of bars that keep my wrist more inline with my forearm. I'm not sure if it would look better or not. But I would rather be comfortable more than anything.
            • #70
              Don't know how I missed this thread either.. but I'm amazed at the artistry. Keep it up!
              • #71
                Got a little more done today,fabricated a mount for the coils and the rectifier,stock coils will be replaced with Dyna coils and wires.
                • #72
                  Got a little more done the last few days,headlight mounted and a little more on the handlebars
                  • Lucky
                    Lucky commented
                    I like the choice of gas tank and the handlebars.
                • #73
                  bump. I like the progress!
                  • #74
                    Started fabricating up the oil tank/electrical box for the bike made out of 1/8" aluminum tank will hold approx. 3 1/2 quarts with another 2 quarts between the filter and oil cooler that is going on and the lines,electrical box will have a drop out bottom and will contain all the electrical and the M-unit and keyless ignition.
                    • #75
                      Looks great you have mad skills !
                      • #76
                        Made a little progress on the oil tank and electrical box and the battery box below the tank which is just sitting there not sure if that is where it will stay.
                        • #77
                          Few more pics of oil tank completed.
                          • #78
                            • Lucky
                              Lucky commented
                              Ebay for the spacers. type in.......Harley wheel spacers Shows front and rear.
                          • #79
                            Just finished fabricating the tanks for the oil cooler and welded them to the cooler core.Want to make sure the oil temp stays down.
                            • Questcap
                              Questcap commented
                              I mean no offense, and it's only a matter of my taste, but I'm big on minimalism, as I thought this project was going to be... why would you think it would need an oil cooler, and it is possible to run oil too cool, so that it doesn't do its job properly... will you use some kind of thermostat to prevent undertemp oil??? I'm grateful for new pics, as it's been awhile... I hope you don't mind my questioning your decision about an oil cooler, I'd love to learn of your reasoning. TIA
                          • #80
                            No offense taken,the reason for the cooler and this isn't set in stone is that i'm not using the transfer gear box which does help in cooling so if I need it I have it if it runs cool enough without I won't put it on.
                            Started by Do Something, 8 hours ago
                            Started by Primetime64, 4 hours ago
                            Started by 2000 Roadstar, 2 hours ago
                            Started by Neverdone, 10 hours ago
                            Started by Swampy, 21 hours ago
                            Started by DEEPHATE, 8 hours ago
                            Last Post 07 silverado
                            Started by DEEPHATE, 9 hours ago
                            Started by Infantryjared1, 5 days ago
                            Started by Blackcloud12, 02-25-2020, 05:10 PM
                            Started by RTT, 1 day ago
                            Last Post RTT
                            by RTT
                            Started by Mic39, 2 days ago
                            Started by scartozi, 3 days ago
                            Last Post Road Star Charlie
                            Started by Ledan, 1 week ago
                            Last Post Cheezhead
                            97 responses
