2008 road star s wont stay straight above 50mph
    If you get the middle 1/3 of your steering travel to not flop, then still have your issue, the neck is not the cause of your issue. With the overturning moment and added weight above the stem of excessively long handlebars, you probably cannot get a clean pass. If your bars are angled forward relative to the steering stem you have an unstable relationship between the axle and the tiller point. Your grips should be a minimum of 5 inches behind the stem. They should equal the axle offset, or be more than the trail, in other words, to achieve good stability and control.
    • oldschoolchopper
      oldschoolchopper commented
      that make sense , I am going to adjust my handle bars and see if it helps , i have been messing with the stem bearing torque , (without a torque wrench ) by feel and its getting better more stable , now that you mentioned the handle bars position which it make perfect sense i am going to adjust it thank you guys , will keep you updated and sorry for the delay .
    I have Adjusted the handle bars moved it back just a bit , , readjusted the fork heights in top clamps (flat with the top clamps on both side ), took some torque off the stem bearing no wrench torque just by feel .... went for a ride , HUGE DIFF below 50 mph pulls to the left a bit [email protected] 70 mph straight like an arrow , above 70 mph i get that wiggle in handle bar not as a bad . flop test wise , it start falling half way of the first 1/3 . , i think its almost there , matter of loosing or tighten that stem bearing a hair . thanks to all of you i start to enjoy my rides again
      UPDATE ....finally i got it right , did the stem bearing by feel / fall away test /flop test . it start falling after the 2/3 of the steering travel . i checked the torque just to know where i am at ,,,,,and it was @ 19.5 ft/lbs .... which proves what hotrod and jd750ace were saying preload torque should be done by feel , forget the numbers !!....THNAKS to all of you guys for the help and thoughts
        Glad you got it sorted out. Feels good, huh?
        • oldschoolchopper
          indeedy bro , i took a trip today about 300 miles felt amazing , thank you . you and hot rod nailed it of course i appreciate everyone's helped and suggested solutions ....
        How do I align my tripple tree clamps? Just Keep the height of the shock tubes flush with top of tripple tree?
          And how does that take out any twist from the top to bottom?
        • Brenden lesage
          Brenden lesage commented
          Thats what im asking. I just rebuilt front forks and added progressive springs, changed my neck bearings. Ever since it seems to wobble. i believe neck bearings are good due to passing flop test but my forks........ dont know how to align them correctly. was seeking advise.
      Started by mariner3302, 2 days ago
      85 responses
      Started by Lug Nut, 6 hours ago
      Started by roadiemort, 8 hours ago
      60 responses
      Last Post Blackcloud12
      Started by Doc_V, 2 days ago
      Started by gonzarelloz, 2 days ago
      Started by estrom, 3 days ago
      166 responses
      50 responses
      245 responses
      273 responses
      Started by Smokescreens, 06-17-2020, 09:49 AM
      Last Post MrG
      by MrG
      Started by MrG, 1 day ago
      Started by Flyinfish, 1 week ago
      Last Post JimH
      by JimH
      Started by JoeX, 6 days ago
      Last Post JimH
      by JimH
      Started by Galcanised, 1 week ago
