Carburetor leaks oil
  • Carburetor leaks oil
    I have oil leaking from under my 2000 road star carburetor.
    Does anybody have an idea of why this is happening?
    If you still have your crank vent going to the back of your air filter box that's probably where it's coming from?
      Exactly as NCB stated. Additionally, over filling the oil, and/or sustained wide open throttle operation makes the oil issue worse.
        Thank you. I'll be checking the level more closely and cleaning that carb when i replace the manifold this weekend.
          This is the best way to check the oil on a Road Star (Same as a Wild Star) Most of us if it does not have a oil leak or is not burning oil, just change it, put in ONLY 4 qts and never check it. Just change it every 3-4k
          https://www.youtube.com/watch?v=QjG18WGbHMg
            Four quarts in, four quarts out. Never check the oil and never add any more. If your not leaking or burning the oil, then the four quarts are still in there.
              First of all, . Second, be sure to read the info here regarding checking the oil. There's a specific procedure, and, even if you follow it precisely you might get 5 different reading if you check it 5 times. If the bike is new to you it's best to just do an oil and filter change with 4 quarts of quality synthetic oil like Mobil 1 V-twin and a good filter like a Napa Gold or Wix, anything but a Fram. You may have to replace the air filter as well if oil is dripping from the airbox.
              • jd750ace
                jd750ace commented
                I'm going to notify everyone as soon as one of my 5 machines with Fram filters in them shits the bed. Internet legend. NEVER seen any filter but a Champion on a IO-360 even be suspect in a lubrication problem, but I don't think it was even a "cause" in that case.
              yes, ive overfilled before while doing an oilchange be careful. 3 bikes, also, , and i have a KN universal air filters that i hooked up the PCV tube from top of rear head . the OEM airbox puts that in the bottom part of airbox so it gets sucked in gradually. with the KN's it messes up carbs with oil. i just got those Up123 filtersand im gonna put them on this week, on the end of that PCV tubing, and plug up air filter. these are washable and reusable. little filters a liitle bigger than a keurig coffee k cup.
                There called crank vent filters:
                https://www.amazon.com/Bikers-Choice...1-0a09f3d4f9b6
                Started by Blackbeard, 1 day ago
                Started by Blackbeard, 11 hours ago
                Last Post Blackbeard
                Started by estrom, 4 days ago
                Last Post Baxter85
                Started by JohnnyBGreen, 3 weeks ago
                Started by LUV4RS, 1 day ago
                Started by Cmw2212, 04-26-2018, 07:38 PM
                Started by Sluggerknuckles, 22 hours ago
                Started by jinxpress, 1 day ago
                250 responses
                86 responses
                Last Post rsokie
                by rsokie
                170 responses
                Last Post StarCruiser06
                Started by gonzarelloz, 4 days ago
                Last Post JimK
                by JimK
                1,009 responses
                Started by mariner3302, 3 days ago
                60 responses
                Last Post Blackcloud12
                Started by Doc_V, 3 days ago
