XV1600 turbo
  • Did you ever end up running it down the drag strip?
    • It's been a while. Got new tires on the bike and thought i fixed the stuttering and accational misfire. Cut and re attached the spark plug wires and changed plugs.
      now the problem is low battery charging AND vibration while driving or on neutral when giving gas.
      If i pull the clutch when driving and let it roll, vibration goes away. So it occurs when giving some load to engine while driving.... Very annoying.
      My engine runs a bit rich beacause of turbo, and i'm gonna do compression test and try some engine cleaning. Belt tension is good, tires are new etc. Gonna check rear swing connections and all that might move under load. Also the front pulley is ok.
      665 responses
      Started by Roadrider, 3 weeks ago
      Last Post TorontoRoadie
      Started by TorontoRoadie, 14 hours ago
      Started by Kmartcivic, 23 hours ago
      Last Post GreenMachine
      1,508 responses
      Last Post Zimasfriend
      Started by FuryGuy, 5 days ago
      Last Post FuryGuy
      by FuryGuy
      Last Post Dogbone
      by Dogbone
      Started by kragos, 5 days ago
      Started by ItBeMe, 3 days ago
      Started by Ben, 3 days ago
