Wireing
  • Wireing
    My start button doesn't work and no juice to my fuel pump
      from Solon, IA. What have you done so far to troubleshoot? Do the gauges sweep when the key is turned on? Your profile says year 2000 1600 so the headlamp should come on with the key. Is it nice and bright/strong?
        Check the fuel pump fuse and clean the contacts on the switch. They are 2 separate issues unless you have a ground wire common to both. You will have to look at the wiring diagram to see.
          I replaced fuel pump with aftermarket .run pump directly to battery ...fine now no power to my coils and start button want work no
            I know this sound like a silly question to ask...but have you checked the kill/stop switch on the right handlebar? If it's off (or switch contact issue) you will not get any start function and the pump won't run.
              from Ontario, Canada.
              "Never ride faster than your angel can fly"
                I checked the button for sure
                • Ratl
                  Ratl commented
                  I’m sure you check the button to make sure it was in the wrong position, but did you check to see if the switch was working? If the kill switch has gone bad, your bike won’t start. It could just be dirty contacts that need cleaning.
                St
                  You should change your screen name to something other than your email address. You're opening yourself up to a lot of spam and scam!
                    What about the kickstand and neutral safety switches?
                    665 responses
                    Started by Roadrider, 3 weeks ago
                    Last Post TorontoRoadie
                    Started by TorontoRoadie, 14 hours ago
                    Started by Kmartcivic, 23 hours ago
                    Last Post GreenMachine
                    1,508 responses
                    Last Post Zimasfriend
                    Started by FuryGuy, 5 days ago
                    Last Post FuryGuy
                    by FuryGuy
                    Last Post Dogbone
                    by Dogbone
                    Started by kragos, 5 days ago
                    Started by ItBeMe, 4 days ago
                    Started by Ben, 3 days ago
