Electrical Diagnostics Help
  • Electrical Diagnostics Help
    My '01 Roadie does nothing when pressing the start button. Nothing. I replaced the starter relay (non-OEM), but no change. Since the end of last season, I've been starting my bike by holding out the decompression solenoid while jumpering across the starter relay with a screwdriver. Works and starts fine, but obviously less than ideal. I'm reasonably intelligent and mechanically capable, but electrical diagnostics are a bit challenging to me. Start switch, kill switch, side stand switch, starter relay...it's all a bit bewildering. Is there a good resource for electrical diagnostics that I can take the problem I have and it will walk me step-by-step through diagnostics? I have a service manual (and multi-meter), but it is not idiot friendly enough for me. Maybe something like this exists on the forum already? If not, this seems like a common enough problem that it would make a great tech article. Thanks in advance and sorry if this has already been covered repeatedly.
    It definitely sounds like 1 of the 3 switches. I don't remember if the side stand and clutch switches need to be jumpered or just unplugged. Maybe someone that has done it will jump in and answer that question. If not 1 of those 2 the start button switch has been a known issue and generally works after cleaning the contacts inside of it.
    • TimB
      TimB commented
      Both the clutch switch & sidestand switch need to be jumered
      Thanks for that answer Tim. I never had to do it so I wasn't sure
    Have you tried simply jumping power to the starter terminal (On the starter) to confirm starter works? Make sure the bike is in neutral before doing this as all safety switches are bypassed!
      Well, he has tried "I've been starting my bike by holding out the decompression solenoid while jumpering across the starter relay with a screwdriver. Works and starts fine, but obviously less than ideal."
      So that tells me that the safety switches are not to blame, otherwise he would not be able to start it.
      Is the starter solenoid being energized? If no, then trace back the wires to the starter switch.
      Have you just tried holding open the decompression solenoid? If so, does it turn over at that point? If yes, is the decompression solenoid being energized? If yes, bad solenoid. If no, then trace back the wires.
      2005 Silverado Midnight Star
        The chines POS relay will fail soon. Reinstall the Yamaha solenoid & if you can start it by shorting the solenoid, it still works. Everything goes through the safety cut-off relay. Test it.
        • TimB
          TimB commented
          I've sold every safety cut-off relay I've ever had. They do go bad.
        All the safety relay does is to stop the START switch from working and run the fuel pump. if he jumps from the starter solenoid it will bypass it,,, so
        1 does the fuel pump run when you turn ignition on ?
        2 do you have 12V on the R/W wire on the starter solenoid ?
        3 do you have 12V or 0V on the blue wire ?
        4 when you push the START switch, what happens to the voltage on the blue wire ?
        Give me an answer to these questions and ill brobably be able to tell you the problem.
        The decomp system has nothing to do with actualy starting, only lifting the valves to make it easier to start,,, as its comtrolled by thr ECU
        Sometimes it takes a whole tank of gas before i can think straight
        • boiler_roadie
          boiler_roadie commented
          Thanks to all responders and especially hotrod460. This is the kind of step-by-step methodology I was looking for. May take me a couple of weeks to get to it.
        • boiler_roadie
          OK, I got to it today.
          1. Yes, I hear it clicking like normal.
          2. I'm assuming this means measured to ground with ignition ON. If so, yes, I measured 12.3V from R/W wire to ground with IGN ON.
          3. With IGN ON, I measured 11.1V from the blue wire to ground.
          4. No change in voltage when start switch is pressed.
          As a sidenote, I stumbled on the thread below today. Lots of good info and detailed troubleshooting. Too bad it's for a Goldwing and the colors don't match up, but it really shows the kind of detail a dummy like me can follow.
          http://goldwingdocs.com/forum/viewtopic.php?t=37447
        • hotrod460
          hotrod460 commented
          Ok, well assuming you have jumped the side stand switch and the clutch switch as mention earlier, and neutral light is on, the there is only two things it can be, the START SWITCH on the handlebars, or the SAFETY RELAY, to test the safety relay, short the BL/Y wire on the clutch switch to earth, the try and start, if it turns over then its the SAFETY RELAY, if it doesnt then its the START SWITCH,,,,,remember this includes any wiring and connectors going to the switch, as connections are normally the problem. good luck
        On my bobber i totaly rewired it and removed the safety relay, the fuse box, the flasher relay,side stand switch, clutch switch, and anything else that wasnt absolutely necessary, and replaced them with an Motogadget M unit. (the M unit includes flasher and fuse control)
        This is my choice and others may see it as bad, but i still have a neutral light, and this is all i need to ride .
        • TimB
          TimB commented
          I have no dash. Only a tach on my bars on my 1100. Safety cut-off relay controls the safety switches(junk), fuel pump & ign box. turning the key to on activates both or should. I'm down to only a few wires in the safety cut-off relay, but I can't see how to eliminate it completely, as I'd like to. I don't have a keyed start switch, just toggle switches & a mini push button for starting. Love my Victory 8Ball tank, planning on another for my R*.
        The relay doesnt control the ECU, i removed my safety relay, and have a wiring diagram you can follow to remove it. PM me
          How did you get on ?? any news??
            Turned out to be the start switch. Cleaned up the contacts and all was well (just like y'all told me back in March!). Good grief. Thanks for all the replies.
              glad you got it fixed !!!!!!
              3,255 responses
              Started by Doc_V, 14 hours ago
              Started by Jaskin71, 3 days ago
              Last Post Jaskin71
              188 responses
              444 responses
              Started by Leadkrm, 22 hours ago
              Started by NthernLgts, 3 days ago
              Last Post NthernLgts
              910 responses
              Started by NCB, 1 day ago
              Started by CarlDeBar, 4 days ago
              Started by RAFAŁ, 1 day ago
              Started by Tdeon, 2 days ago
              Last Post BSeward
              by BSeward
