Front fork rebuild
  • Front fork rebuild
    I'm trying to rebuild front suspension with progressive springs. I can't seem to find a complete kit for my 2001 1600. Any help as to which of the hundred springs would be best or let me know what you all have used. Thanks
    I did the racetech setup. Springs and emulators. Complete transformation. Paired with my roadwing is works awesome.
    i like that the racetech springs are designed for your wieght not some "average" rider.
    i know one fb guy is very against the emulators but several have used them succesfully. JD750ace was able to get me fixed up over the phone.
      I have a progressive lowering spring set up new in box I would sell for 40 plus shipping. I won't be using them.
        The Progressive spring number for R* 1999 to 2003 is 11-1144FS Kit. This is what I installed in my 2003.
        hope this helps.
          You won’t find a parts kit available, although you can find people that will do it for a (hefty) package price. As stated above, I highly recommend Race Tech Springs and emulators for the ultimate riding experience. If you just putt around town and are more about being seen by people you know than being seen in places where nobody knows you, then it’s probably not worth it to you. Rock River Powersports was (remains) instrumental in the existence of this site, so I myself am committed to buying every OEM Yamaha part I need through them.
            +1 on the Racetechs. Did mine without the emulators and it's still a 300 % improvement. As stated their nice because you order them for your weight, not just a generic spring made for everyone's weight.
              Don't know about Racetech springs, but I used Sonic straight rate springs in my Royals Star Venture and plan on using them on my '09 RS. The guys over at venturerider.org swear by them. They are very reasonable and their support is second to none. The ride on my RSV was like a new bike and handling is amazing. They also make springs for the RS. Sonic talks about straight vs progressive springs on their site and it makes perfect sense to me anyway. Progressive springs work very well on dirt bikes with their long 10+ inch travel but on road bikes with limited travel may make some use of progressive springs but they get better performance from straight rate springs that are suited to the bike they are intended for. You can also get emulators from them also. Makes sense to me as their is very little progression going on with 5" of travel.
              Anyway, I am far from being knowledgeable enough to argue either way. Lord knows I've been sold the Brooklyn bridge more than once over the years, but value vs cost, you can't beat the performance of Sonic vs stock springs. And, they are made right here in the USA.
                I'll be another vote for Racetech springs. A vast improvement that is the perfect rate from second one unlike progressives which might not reach the spring rate that's correct for you until they're half compressed. Progressives are better than stock, but Racetech's are better yet, just ask Smokescreens since he's had both.
                  I too did the Racetechs and they are the hot ticket! I still want to do the emulators too.
                    I have my RT springs and Emulators. Waiting on new Bushings and Seals to do the job.
                      Well I got it mostly together and just realized I put my Rebound Springs under the Upper Tubes and they go inside at the bottom. GRRRR !!! Oh well , Oil not in yet. Speaking of Oil , what is the level I need ? I'm 200 lbs. and have about 40-50 lbs. of stuff on board Solo. .95 Racetech Springs and Gold Emulators installed.
                      • FDRUCaptain
                        FDRUCaptain commented
                        Front spring and oil weights are only figured based on the rider weights, not rider + passenger or gear. With that said though, Racetech recommends 15w fork oil with their springs and emulators. I used Belray fork oil but others may be biased towards something else.
                      Thank You . What I"m needing is the Oil level for my 200 lbs. with the .95 RT Springs and Emulators.
                        Try this
                        http://www.racetech.com/ProductSearc...adstar/2004-12
                        Started by Questcap, 3 weeks ago
                        Started by Doc_V, 02-28-2018, 10:17 AM
                        523 responses
                        Started by sta-lor, 03-19-2018, 05:03 PM
                        Last Post H.d.U
                        by H.d.U
                        Started by roadiemort, 16 hours ago
                        Started by FDRUCaptain, 3 days ago
                        Last Post geraint
                        by geraint
                        Started by K.Conant, 1 week ago
                        Last Post BLKACE
                        by BLKACE
                        Started by Mdowl17, 13 hours ago
                        Started by JD64k, 3 weeks ago
                        Started by Assocracer, 14 hours ago
                        Last Post Assocracer
                        Started by geraint, 17 hours ago
                        Started by FDRUCaptain, 1 week ago
                        50 responses
                        Started by G_Conway, 15 hours ago
                        Started by Tykes_Place, 02-13-2018, 11:49 PM
                        Started by Tykes_Place, 1 day ago
                        Last Post HotRod
                        by HotRod
                        Started by BubbaKahuna, 21 hours ago
                        Started by Peter G, 1 day ago
                        Started by YZ18, 16 hours ago
                        Started by Jaybo, 03-10-2018, 07:31 PM
                        100 responses
