Correct Oil Filter, or an ALERT!
  • #41
    Here is a good read for you guys to better understand what a bypass valve in an oil filter is for. It don't work the way that has been said above. It opens when oil is cold and thick to prevent a lack of oil supply and opens if the filter becomes plugged. Other than that your oil all gets filtered when the bike is running.
    http://www.baldwinfilter.com/TechTips201409.html
    Our bikes don't have a deep sump or High pressure/high volume oil pump like what you would find on a race car. It is not at all like a system in a race car. in fact if you have a race engine that is bypassing dirty oil into the engine you need to modify your filtration system with a return oil filter like this.
    http://www.machinerylubrication.com/...ass-filtration
    • #42
      Ah, cool... I was mistaken then. I had read that the small cans would pass 8 to 10 gals a minute, while the larger cans would pass 9 to 11 gals per minute. From that I surmised, wrongly, that more than 8 to 11 gals was being pumped, and the rest must be bypassing. I'm actually pleased to learn that other than when cold and thick, or clogged, it's all going through the filter medium.
      Now, I think it worth adding... we that use a synthetic probably know that it flows much easier than dino, even when cold. One of the principal benefits of synthetic is its ability to flow and lubricate better during cold starts, and especially cold winter starts. Now, we can probably add the benefit that likely most, if not all, also goes through the filter element even upon a cold start up, too, since it's not typically near as thick as cold dino.
      On top of that, if it's almost all always going through the filter medium, I would think it most unusual that hardly any steel residue could accumulate on a drain plug magnet... and, so I'd be even more interested in what guys using magnetic drain plugs have ever been finding on their plugs when they pull them for an oil change. Seems there should normally be just about 0 on them. Thanks for the correction, Dave.
      Started by pumppy10, 7 minutes ago
      Last Post pumppy10
      Started by Lug Nut, 4 hours ago
      Last Post daveto
      by daveto
      Started by gary1717, 1 day ago
      Started by Curt, 05-07-2018, 10:04 PM
      Last Post SKWEARpeg
      Started by Hawk, 1 hour ago
      Started by cike, 1 day ago
      46 responses
      1,031 responses
      Started by Rodzim, 20 hours ago
      Last Post BlackCloud
      Started by Shores, 4 hours ago
      Started by YZ18, 2 days ago
      Last Post dnalen
      by dnalen
      Started by Biff, 3 days ago
      Last Post Txulrich
      Started by FDRUCaptain, 5 days ago
      Last Post Jeaston
      by Jeaston
      Started by sycloneman, 1 day ago
      Started by uncledaddy, 8 hours ago
      Last Post daveto
      by daveto
      Started by Traviser, 2 days ago
      Last Post TwinCreeks1600
      Started by Val K, 2 days ago
      Started by Mark_N, 20 hours ago
      Last Post SKWEARpeg
      Started by thehathaways, 4 days ago
      Last Post Littlebull
