2005 Roadstar front pulley
  • 2005 Roadstar front pulley
    I am sure this has been covered somewhere. I bought a front 33 t front pulley from a 2003 1600 Roadstar and want to install on my 2005 1700 Roadstar which has 32 t front pulley. Took the cover off and the 2003 33t pulley looks wider. Will this pulley work on my 2005. If not where do you get a 33t pulley for a 2005 100 Roadstar.
    Thanks
    from Solon, IA
    Yes the early years had the wider belt and pulleys. You can use the wider front pulley with the narrow belt. Not sure which nut and washer combo you have. On my '08 the nut gets staked so it's good to get a new nut and washer. Most here will also suggest red Loktite to make sure everything stays in place.
      Yes it will work just fine. I used a 2000 pulley on my 2008 fuelie. I kept the stock rear pulley. I love the change. Don't try to align the rear wheel by having the belt run in the middle of the rear pulley. Instead, you should measure from the center of the swing arm pivot to the center of the rear axle and make sure it is the same on both sides. The belt will just ride where it wants to.
      BubbaKahuna
      Administrator
      Tykes_Place
      Admin
      Started by penningpd, 15 hours ago
      Started by Jeanson105, 1 hour ago
      Last Post Jeanson105
      Started by ACEMUSTANG2002, 20 hours ago
      Started by Duke, 4 weeks ago
      39 responses
      Started by roadiemort, 08-08-2019, 08:03 PM
      Last Post ABCarr
      Started by brianmac, 2 days ago
      Started by ABCarr, 4 days ago
      Started by BubbaKahuna, 08-17-2018, 03:46 PM
      Started by Jeanson105, 5 days ago
      Started by Tykes_Place, 11-17-2021, 01:09 AM
      93 responses
      Started by Purplestar, 2 days ago
      Last Post Purplestar
      Started by Jkeenan87, 3 days ago
      Started by ACEMUSTANG2002, 4 days ago
      Started by BrokenWheel, 5 days ago
      Started by Kmartcivic, 10-18-2021, 02:50 PM
      Started by Purplestar, 4 days ago
