Battery recommendations
    Originally posted by a_gunslinger View Post
    None of the suggested batteries fit in my RS Silverado 2012. :/
    Go it thank. I was having some starting issue and in another post they suggested upgrading to a 270 or 310 CCA battery. Guess thats not an option, although Im wondering if I could adapt that battery box.
      The napa brand agm is made by deka, 310cca and can be picked up local
        I think after 2008 the battery box is smaller and it cant accommodate the 270 and 310 cca batteries
          Yep.
        Okay I'll say it again adding acid to a battery by the end-user purchaser is passe. AGM batteries are superior. Batteries are like tires they have born on dates. Now they are totally sealed and they can mail them.
          I have had a few AGM batteries that were delivered empty and a acid pack was shipped with them. I filled them and did an initial slow charge before installing. You have to fill them and then wait for about an hour for the mat to saturate with acid before charging.
        • DEEPHATE
          DEEPHATE commented
          That I have never heard of. What battery company does that?? EDIT: Don't answer, I just Googled it. I stand corrected!
          Like davej said. I myself now wait at least 8hours before starting a slow charge. I read from one of the battery companies, that after adding acid to the cells, wait 3 to 4 hours for the mats to be fully saturated before charging.
        Understood, and agree. But I cant find an AGM 270 or 310 CCA that will my 2012.
          The fuelie bikes don’t need all that cranking power. What is a battery for but to start the bike? That’s it. Mine fires off on the first or second chuff every time be it 30° or 100°. If you are having problems with getting your bike to start then something is amiss.
          I left you a link for what you need. No big deal adding the acid. Once done you snap on the caps and it is sealed. There’s no vent tube to slobber all over the bike. My last Yuasa battery lasted seven years.
          https://www.roadstarclinic.com/forum...125#post107125
        Find a battery cross reference chart?
        https://www.yuasabatteries.com/wp-co...Guide-2019.pdf
        • #27
          looks like you may have to add acid to these.....................then they get sealed.
          looks like deka and everstart do not make a yt14b-bs, only sigmas tek
          If you need more help with purchasing your Motorcycle Battery, please call our customer service department at (800) 657-1303 or e-mail us at [email protected].
          SigmasTek Yuasa Deka Everstart Volts AH CCA Polarity Length (in) Width (in) Height (in) Weight (lbs)
          STX4L-BS YTX4L-BS YTX4L-BSFP ES4LBS 12 3.5 50 -/+ 4.49 2.80 3.39 3.17
          ST5L-BS YTX5L-BS YTX5L-BSFP ES5LBS 12 4.5 80 -/+ 4.49 2.80 4.21 4.14
          STZ7S YTZ7S YTZ7S ESTZ7S 12 5.5 130 -/+ 4.45 2.76 4.21 4.27
          STX7L-BS YTX7L-BSD YTX7L-BSFP ES7LBS 12 6 100 -/+ 4.49 2.80 5.12 5.44
          STX7A-BS YTX7A-BS D YTX7A-BSFP - 12 7 105 +/- 5.94 3.46 3.70 5.81
          ST7B-BS YT7B-BS YT7B-BS - 12 6.5 110 +/- 5.94 2.56 3.66 5.09
          ST9B-4 YT9B-BS - - 12 8 115 +/- 5.94 2.76 4.13 6.28
          STX9-BS YTX9-BS ETX9 ES9BS 12 8 120 +/- 5.94 3.46 4.21 6.19
          STZ10S YTZ10S - - 12 8.6 190 +/- 5.91 3.43 3.66 5.99
          ST12B-4 YT12B-BS - - 12 10 210 +/- 5.94 2.76 5.12 8.04
          ST12A-BS YT12A-BS - - 12 10 175 +/- 5.91 3.43 4.09 7.69
          STX12-BS YTX12-BS ETX12 ES12BS 12 10 180 +/- 5.94 3.43 5.16 8.06
          STZ12S YTZ12S YTZ12S - 12 11 210 +/- 5.94 3.43 4.33 6.98
          STZ14S YTZ14S YTZ14S - 12 11.2 230 +/- 5.94 3.43 4.33 7.62
          STX14-BS YTX14-BS ETX14 ES14BS 12 12 200 +/- 5.94 3.43 5.79 9.43
          STX14L-BS YTX14L-BS ETX14L - 12 12 200 -/+ 5.87 3.43 5.71 9.43
          ST14B-4 YT14B-BS - - 12 12 240 +/- 5.94 2.76 5.79 8.99
          STX15L-BS YTX15L-BS YTX15L-BSFP - 12 13 230 -/+ 6.89 3.39 5.12 9.91
          STX14AH-BS YTX14AH-BS ETX15 ES14AHBS / ES14AA2 12 14 210 +/- 5.28 3.54 6.64 10.42
          STX14AHL-BS YTX14AHL-BS ETX15L ES14L-A2 12 14 210 -/+ 5.28 3.50 6.54 10.42
          STX16-BS YTX16-BS - - 12 14 230 +/- 5.94 3.46 6.34 9.82
          STX16-BS-1 YTX16-BS-1 - 14 12 14 230 +/- 5.91 3.43 6.38 9.82
          STX20CH-BS YTX20CH-BS - - 12 18 260 +/- 6.00 3.44 6.38 10.90
          STX20-BS YTX20-BS ETX16 - 12 18 270 +/- 6.88 3.43 6.13 11.61
          STX20L-BS YTX20L-BS ETX20L - 12 18 270 -/+ 6.89 3.43 6.14 11.61
          STX20H-BS YTX20H-BS YTX20H-BS - 12 20 310 +/- 6.85 3.39 6.14 13.44
          STX20HL-BS YTX20L-BS - ES20LBS 12 20 310 -/+ 6.89 3.43 6.14 13.44
          STX24HL-BS YTX24HL-BSD ETX18L ESC50N18LA3 12 22 350 -/+ 8.07 3.50 6.46 15.68
          STX30L-BS YTX30L-BS - - 12 30 385 -/+
          • #28
            i can t tell if the sigma tek is factory sealed, cant vouch for its quality, no knowledge of it
            • #29
              Yeah, looks like I not going to be able to ever have more than 210 CCA
              • #30
                It’s all my ‘09 ever needed.
                • #31
                  Suunds my battery just needed a full proper charge on a real charger, not just on the trickle charger. Its behaving better now with a full charge on the stock 210 battery.
                  • #32
                    With regular riding times a battery shouldn’t need any assistance from an external charger. Verify the charging status with a volt meter. Should see 14 volts at a very fast idle across the battery posts.
                    • #33
                      Yeah and clean inspect connect shuns
                      • #34
                        The stock YT14B-BS is a dry shipped AGM battery. The purchaser adds the acid and charges it. It is a sealed maintenance free battery. Just put one in my '12 a couple weeks ago. The specified 210 cranks it just fine.
                          Were there any special instructions for charging? I think I recall Doc_V a while back talking about using a trickle charger and giving it a 24/48 hour charge before use?
                      • #35
                        It was recommended to me to fill it and let it sit for 24 hours if possible. Then charge it on trickle charge with the acid bottle still attached just so it can breathe if it needs to and not bubble everywhere (in the event it does so). Then seal it up and be good to go.
                          I always left it overnight after filling but always sealed it before charging as per instructions, I'm not a bomb builder.
                        • Blackcloud12
                          Blackcloud12 commented
                          It was the Yamaha dealer tech that told me that they charged them with the cap off and then sealed it up afterwards. Don't know what they had found from previous experience.
                      Started by dennishiggins, 27 minutes ago
                      Last Post dennishiggins
                      Started by lowriderbob, 19 hours ago
                      Started by roadiemort, 16 hours ago
                      Started by Darkkill57, 23 hours ago
                      Started by Phix, 1 day ago
                      Started by ItBeMe, 1 day ago
                      1,021 responses
                      Started by ItBeMe, 2 days ago
                      Started by D-Fresh, 1 day ago
                      Started by Lucky, 4 days ago
                      Started by davej, 1 week ago
                      Last Post tovarman2
