I purchased a fairing for the bike and it will be here monday, it has a gel coat on it. I was wondering if I need to repaint or if the gel coat is good enough, I have seen both ways on the internet
bought a fairing
Search Results
Featured snippet from the web
Gel coat, like paint, fades (changes color) and oxidizes (chalks over) due to exposure to UV light over time. Polishing removes a thin outer layer of gel coat exposing less damaged material underneath. Oxidizing tends to be a surface effect while fading is much deeper in the material.Jun 14, 2018
heres the little i know about gel coat.
if it is truly gel coat, than it is a fiberglass fairing. in that case, polyurethane or more noble paints need to be used. other paints will stick, but not bond, as far as i know from boat stuff. gel coat is allegedly a company specific mixture of poly,vinyl,epoxy esters with coloring added and UV stuff,and waxes, and all that BS.....basically nothing likes to bond to it. i do know that epoxy will bond to vinyl-ester, both will bond to polyester, but the reverse direction is not true.
these boat guys down here make a living buffing out faded gel coat...boats. i should have added, any repairs or additions should use epoxy resin, I use standard fiberglass coloring agents in epoxy. nice thing about epoxy, say you have a hole needs to be filled. mix 1 hour epoxy, add coloring agent(s), alllow to just start to get viscous and quickly apply, now dip gloved finger in 91% alochol from walgreens, you can smooth it out to where it does not need sanding before it cures, wipe area around it with alcohol. .dont breathe vapors
Fiberglass does not like to bolted or screwed. Sheet metal or wood screws tend to vibrate out. Bolts typically transmit all vibration from the motor to the windshield . you may even hear resonant sounds. Also if you over tighten the bolts they can cause cracking in the bolt area the best practice is to have rubber bolt grommets. Slipstreamer will sell you a handlebar mount kit designed to go through like a three-quarter inch hole in the fairing with a rubber washer on each side. You have to tell them you replacing your old one. I have good luck with aluminum bar three quarters of an inch by 1/8 you can bend it easily And drill it. and it doesn't rust. They make these little things that go on your handlebars for mounting a mirrors, cheap ,like 3.99 499 or less designed to go onto the handlebars 7/8 or 1 inch and you can bolt the aluminum bracket to that, other end goes to the fairing. If standard OEM bracket is not enuf. I have even used the upper triple tree bolt to mount fairings course you need a longer bolt sometimes
Started by Mad Maj, 5 hours ago
by Mad Maj
25 minutes ago
Started by Sykobox, 2 hours ago
by Mr. Miyagi
57 minutes ago
Started by KFallsRider, 4 hours ago
by Mr. Miyagi
58 minutes ago
Started by 6door7r, 8 hours ago
1 hour ago
2 hours ago
Started by roadiemort, 4 hours ago
4 hours ago
Started by Kmartcivic, 14 hours ago
by Engineman
4 hours ago
Started by Mad Maj, 2 weeks ago
by Mad Maj
5 hours ago
Started by brianmac, 16 hours ago
by Shotround
11 hours ago
103 responses
by Bnag0
Started by 6door7r, 4 days ago
by Chromepony
Started by Tykes_Place, 3 weeks ago
Started by p birk, 5 days ago
by Tcontrol
57 responses
by Shotround
Started by luff_tackle, 2 days ago
Started by jb3472, 3 days ago
Started by ABCarr, 5 days ago
by ABCarr
Started by BloodMoney, 04-15-2022, 02:28 PM
by BloodMoney
