Modify rear hub to fit raider wheel
  • Modify rear hub to fit raider wheel
    Is there anyone that can modify the rear hub to fit raider wheel? I remember a while back someone came up with this mod. Thanks
    The Roadstar either has a spoked wheel and hub or a mag wheel. The raider has only a mag wheel. Are you talking about just the pulley hub?
      Pulley hub and pulley has to be milled.
        Tom Lento Punch on the FB clinic site makes a kit so you can use a HD rim on back. .. $500....but looks very nice
          This is how I did it.
          On my 06 1700 RS, I removed the brake mount on the swing arm to clear the wheel and tire, so that will have to be addressed. I removed the the part on the hub that the seal seats in the hub down to about 25 thousands above the c-clip.
          The inner collar was cut down 200 thousands (any machine shop can do this) and the pulley side wheel spacer will need to be trimmed down also I used a 1 1/8th pulley for a HD soft tail for some bling (Chrome and EBay).
          It is a 70 tooth pulley same as a stock RS pulley. You will need to drill the holes in the HD pulley to fit the RS hub studs.
          I used a caliper and a brake mount off a Raider for my rear brakes, (Thank god for EBay again) but I believe the Statoliner and RoadLiner are the same.
          I used a Baron Phat rear fender which is fiberglass, so no riders. I have a metal one that I purchased but have not got around to installing it and have painted.
          If you are good at body work you could widen the stock rear fender. There was a member a few years back that did this and it looked pretty good.
          If you go with a different fender you will have to install and wire a tail and turn lights.
          The stock tire on the Raider is a 210, I run a 240mm tire and the rim is 18 inch.
          I have put around 5000 miles on it since I put my Raider wheels on, it would have more miles on it but I also have a 2012 RS I ride and took to Sturgis back in August.
          This was not a quick or cheap job, and these few sentences does not do it justice, also if you asked me would I do it again - Hell Yes.
          Ride safe
          Mike
            Thanks Mike.
            Do you have any pics?
              I sent you a PM.
              Started by RoadieRob, 21 hours ago
              Last Post RoadieRob
              49 responses
              Last Post tapeit59
              Started by twowheeltherapy, 5 days ago
              Last Post twowheeltherapy
              Started by cap-tech, 6 days ago
              Started by Bear1433, 1 day ago
              Last Post Bear1433
              Started by Cubo55, 2 days ago
              46 responses
              Last Post Blackcloud12
              Started by NCB, 4 days ago
              Started by YZ18, 1 day ago
              Last Post GuernseyLad
              Started by coolalexrex, 1 day ago
              Started by J89k, 2 weeks ago
              Started by Angel220, 5 days ago
              Started by Jaybo, 5 days ago
              Started by Jaybo, 2 days ago
              Started by kwarten, 1 week ago
