clutch slippage
  • clutch slippage
    I saw this on fb and was wondering if anyone has experienced this "Andrew Pellerito I got stock clutch and I get clutch slippage when running full synthetic engine oil and I get absolutely no clutch slippage running Castrol 4 stroke motorcycle oil non synthetic "?
    Could be using wrong synthetic oil. Does he mention what brand? Probably doesn't.
      no he did not
        Likely used car motor oil. It has been mentioned a few times on here and the old clinic. Oil isnt just oil even if synthetic or not.
          I sent him a message and am waiting his reply
            He might have used a synthetic with friction modifiers. That's a no-no.
            PGR
            PGT MT
              I think just about every RSC member uses full synthetic of one brand or another, and no one else's clutch slips. Yea, there may be some omissions to this story.
                Synthetic has zero to do with clutch slippage. The issues is whether or not he's using a *motorcycle specific* oil designed for a wet clutch or an automotive oil, especially if it has friction fighters, as Tykes_Place mentioned.
              he responded and said this; Oh sorry for delay was running Amsiol 20W50 full synthetic
                Well, I run Mobile1 20W50 v-twin full synthetic. My clutch was slipping in 4th gear. I have 33k on the bike. I replaced the clutch spring with the EBC spring and that felt like it did the trick for about 1k now I'm back to slipping when I really get on it? Opinions?
                  The EBC is a band aid fix...not a whole lot stronger than stock. You could also have worn the clutch discs and maybe glazed the steels. If you want to do it right and be done with it for likely the entire time you own your bike...do the following:
                  get the Barnett Spring Conversion kit, new OEM Yamaha clutch discs,and new OEM Yamaha steels. Not aftermarket clutch discs and steels. Stock ones. Adjust clutch cable properly. Period. End of story. Probably get 75k-100k out of that setup (if not longer).
                  Started by twowheeltherapy, 1 day ago
                  Started by NCB, 7 hours ago
                  Started by daveto, 7 hours ago
                  Last Post daveto
                  by daveto
                  Started by Grease, 03-04-2019, 08:08 PM
                  43 responses
                  Started by Jaybo, 1 day ago
                  Started by Angel220, 1 day ago
                  Last Post Angel220
                  Started by Airlordd1, 1 day ago
                  Started by Pauli466, 4 weeks ago
                  Started by Zachhaynes922, 4 days ago
                  Last Post Zachhaynes922
                  Started by curtixman, 5 days ago
                  Last Post highvoltage
                  Started by cap-tech, 2 days ago
                  Started by JoeBloShmo, 1 week ago
