oil temp gauge installed
  • oil temp gauge installed
    Well i finally got all the parts from ups and got it installed today. I had a spare oil drain nut and drilled and tapped it to 1/8 pipe threads for a place to mount the sending unit. I bought a longer bolt and used it to mount the new gauge under the tach under the handlebars. I done a short 10 mile run to give it a whirl and she worked great. The outside temp was 63 degrees and oil pressure was 22psi and oil temp was 200 at 1000 rpm idle. When the bike was cold the pressure was 60 psi at idle.
    Gauge mod and assembly
      assembled
        mounted under tach
          I wanted a gauge that read 300 degrees plus, but i settled on a 280 instead from oreilly auto parts.
            It will get as high as 260ยบ or so in the summer, depending on the riding you are doing.
            Started by Knutselsmurf, 8 hours ago
            Started by RoadieRob, 1 hour ago
            Started by Pauli466, 1 hour ago
            1,340 responses
            Last Post Ret HPD
            by Ret HPD
            Started by Sguitard, 3 days ago
            Started by Aussie John, 6 days ago
            Started by 2time, 1 day ago
            56 responses
            Started by coreys1982, 2 days ago
            Started by LUV4RS, 4 days ago
            Started by Cubo55, 5 days ago
            Started by MikeyC, 4 days ago
            Started by tapeit59, 2 weeks ago
            Started by 03LiquidSilver, 06-07-2019, 02:33 PM
            Last Post ryanjam
            by ryanjam
