Hiccup on accel while warming up
  • Hiccup on accel while warming up
    Hi all,
    I've had a small issue I've been meaning to address. My bike will often (60% of the time) give me one hiccup on acceleration if the engine isn't warm. This will sometimes lead to the bike stalling. This never happens after I've been riding for a bit (maybe 10 min) only when the bike still seems to be warming up. It also never happens more than once each time I use the bike. The bike has stalled at a few inopportune moments over the last few weeks, so I'm motivated to get it sorted.
    The carb was rebuilt about 18 months ago when I first bought the bike. Baron's needle, mikuni jets (full settings in profile). I replaced all diaphragms. I did a good cleaning on it probably 4 months ago when I replaced all the fuel lines.
    I have a vance and hines 2 into 1 exhaust that I recently baffled. 14 months ago one of the posts for my exhaust sheered off. I had to drill it out and install a new post. I mention this because it could be a potential point of air leak. I replaced both copper seal washers when I first bought the bike 3 months before the exhaust post sheered.
    My idle is set at 900. Used a tiny tach to dial it in.
    My intake manifold is stock (04) as far as I know. It's been on my list to replace. I've never pulled it, but assume it's in rough shape as every other piece of rubber I've replaced on the bike has absolutely needed it (AZ life). I have fresh gaskets for it that I haven't yet installed. I haven't ordered a replacement intake yet but have been seriously considering it.
    Tell me your thoughts.
    Colder temps my bike would need a longer warmup. I went up one size on pilot jet and helped greatly with enricher half out. You may want to give it a try with enricher half out first.
    • J89k
      J89k commented
      I do use the enricher on start up.
    When you start the bike do you use the enricher at all? Like mentioned maybe pull it out just a tad (half or less) and ride for a few (5-7) min like that. Do that consistently for the next 10 times you ride and see if that helps. Can spray some starting fluid around your intake manifold while idling and see if you have a leak also.
    • J89k
      J89k commented
      I do use the enricher if I'm starting the bike cold. I leave it on for the first 5-10 min the bike is running. The enricher is typically in use when this happens.
    Partially plugged pilot if you are getting stumbling or air leak. Spray carb cleaner around carb intake and joints see if idle drops.
      It's kind of the nature of the beast that they do this. Remember this is basically 1910's technology, the V-Twin is not the most efficient way to make power. Two big holes, sucking through one smaller hole, you're bound to get some confusion in there sometimes. I can't speak for the F.I. bikes (never had one) but I know from experience that ANY carburated, large displacement V-Twin is gonna spit and sputter now and then, regardless of how perfect tune it's in. If you demand a rock solid idle get an inline four.
      • J89k
        J89k commented
        Could be that this is just how she runs. It's my first bike. Nothing to compare my experience to.
        Ride daily. 16k miles since I bought the bike.
      When's the last time that you drained your fuel tank and let it dry out may have water in fuel. Check air filter. Is it spark plugs time yet? Electric ignitions will eat up spark plugs
      • J89k
        J89k commented
        I got some ngk iridiums when I bought the bike a bit over a year ago.
        I've never drained the tank and let it dry.
      bump due to spam on board
        Adjust the accelerator pump cam to get a little more duration on the squirt. It coughs because its too lean when cold
          Adjust the PMS screw again. Adjust to high idle, then turn out 1/8 of a turn.
            Check accelerator pump... Let it run longer with enrichner. before blipping the throttle or quick acceleration.. Cold cylinders do not like sudden acceleration
            • Jim Simmons
              Jim Simmons commented
              Look for a leak. I had those exact same symptoms with a freshly rebuilt carb. Followed RSC advice to the letter. Turns out it was a newly developed air leak around the manifold. (Probably generated by my messing with the carb too much). There's also a trick to getting the intake mounted correctly. I wedged the intake down (compressing the o-rings) by pressing against the bottom of the frame top tube. Then put the bolts in. I tried to tighten them slowly and evenly, starting with the bottom first. I did flat sand it on my measuring table with 220 grit sandpaper. And I put new O-rings in. And that got rid of the stumble. A close examination of the plugs (too lean) revealed that there was extra oxygen coming in from somewhere... Hence the stumblehunt. Good luck. And get the ported manifold. It's actually a really noticeable difference when you put it on. The intake sounds become deeper more distinct. Hard to describe. I think it's an improvement. And there is a noticeable hp bump if it's paired with a BAK or some other free flow filter. Good luck.
            • J89k
              J89k commented
              Jim Simmons I've had a sneaking suspicion its the manifold. The desert has been harsh on ALL the plastic and rubber on the bike.
          165 responses
          Started by Knutselsmurf, 1 day ago
          Last Post Knutselsmurf
          Started by RoadieRob, 19 hours ago
          Last Post RoadieRob
          Started by Pauli466, 20 hours ago
          Started by ctkog, 16 hours ago
          1,343 responses
          Started by Sguitard, 4 days ago
          Started by Aussie John, 1 week ago
          Started by 2time, 1 day ago
          56 responses
          Started by coreys1982, 3 days ago
          Started by LUV4RS, 5 days ago
          Started by Cubo55, 5 days ago
          Started by MikeyC, 4 days ago
