Heel shifter
  • Heel shifter
    I think the heel shifter after 2003 looks too much like the end of the side stand, i think i will get rid of it.
    Won't your bike fall over?!?!?
      Can cut it easily enough or see if someone want to trade a toe only shifter for it.
        Pauli466 as Lug Nut said, maybe someone would be interested in a trade with you. To be honest, I prefer that style heel shifter. I sat on an older R* a dealer had (while I was still tire kicking) and didn't like the old style. I thought it was tough to get my boot into place on the floorboard. Of course had I bought the bike I may have adjusted to it, but it was a concern to me as soon as I sat on the bike.
          06 was the year they went to the 2pc. from the early 1 pc 99 to 05 design.https://www.partsfish.com/oemparts/a...ed/shift-shaft
            https://www.partsfish.com/oemparts/a...8d/shift-shaft
              06 and up 2 pc. shifter
            I'd only ever used a toe-shifter, so I cut the heel off, and ground it down some to clean things up. It's plenty easy to do.
              Kind of a goofy thread. The earlier shift levers were one piece and many just cut the rear lever off. The newer, two piece does resemble a side stand part so why are folks talking about taking a hacksaw to it?
              If you’re referring to the ‘06, and newer foot shift lever, then just remove bolt #12 and slide it off.
                They have not figured out that this is not Facebook, lol.
              I did slide it off, maybe i can find something to stick over that ugly spline sticking out a piece of hose should work.
              the bike is new to me and i found myself trying to push the shifter out like a side stand the shifter is exactly where my 650 kick stand was
                A few years back I was lucky to score Yamaha OEM aftermarket single shifter I got one for each of the three Banks they are rare as hen's teeth I cut off one for my buddy brother-in-law. You can get circular saw metal cutting blade for a couple of dollars at home Depot and put it in an old circular saw watch out the Sparks will fly and cause a fire do it in the grass it will of the iron do not let the sparks fly all over your cars or motorcycles unless you want to get a little tiny rust spots all over everything when it rusts.
                165 responses
                Started by Knutselsmurf, 1 day ago
                Last Post Knutselsmurf
                Started by RoadieRob, 20 hours ago
                Last Post RoadieRob
                Started by Pauli466, 21 hours ago
                Started by ctkog, 17 hours ago
                1,343 responses
                Started by Sguitard, 4 days ago
                Started by Aussie John, 1 week ago
                Started by 2time, 1 day ago
                56 responses
                Started by coreys1982, 3 days ago
                Started by LUV4RS, 5 days ago
                Started by Cubo55, 5 days ago
                Started by MikeyC, 4 days ago
