RAP for roadwing
  • RAP for roadwing
    I got the rap for the shock today, i iooks like it can hold more fluid than the honda electric setup, has anyone blown out the damper seal using a rap, mine came off a bmw 1100, it look like it will push a lot more fluid than the honda pump
    This should give you an idea on how much fluid needed. The quantity is not important just do as per the youtube video and will work A1. Mine starts to feel preload pressure about 3/4’s of a turn.
      It'll be fine. Many have that same setup and no issues at all.
        No issue on my part with this setup.
          I have the roadwing installed and the rap starts pressurizing right about 3/4 of turn from full open,the bushings from McMasters weren't quite right two shims were required on each bushing half, took me a while to figure how to get the swing arm in without a helper, but with a lot of small blocks and a bungee i got it lined up, for mounting the rap i put a longer bolt into the muffler bracket and stuck the rap over that. Its Just behind the transfer case against bottom frame tube, can hardly notice it. The damper definitely comes out further with the rap at least 3 to 4 mm more than the electric motor, ill have to wait til april to try it out, i almost forgot about the belt when i was manuvering the swing arm into place,
            Been using the same RAP for years now with zero issues.
              Good to hear Pauli you installed it! You will be greatly rewarded with an awesome ride. JC
              Started by Pauli466, 1 hour ago
              Started by Tsilk87, 1 hour ago
              Started by McVinny614, 1 day ago
              Last Post Blackcloud12
              Started by Doc_V, 1 day ago
              Started by Shores, 3 days ago
              Started by MrG, 18 hours ago
              Started by Pauli466, 20 hours ago
              Started by Shores, 17 hours ago
              46 responses
              Started by Oldsguy1, 2 days ago
              Started by Lug Nut, 07-22-2020, 05:21 PM
              143 responses
              Started by Brabbit, 3 weeks ago
              Started by marcus, 1 day ago
              Started by Galcanised, 1 day ago
              Last Post MrG
              by MrG
