This seasons math question....
  • This seasons math question....
    Edit ***I know I can get close after I get all the hardware together and plank secured with the bike loaded, but I’m just eyeballing until then and I’d rather move the chock a little then the plank.
    Roughly.... where is the Roadstars center of weight (front~rear)?
    Where would be the preferred position of center in relation to a light weight trailers axle?
    I’ll be securing a plank to the trailer for a 1,200 mile haul.
    I decided it’s to cold to ride from KS to AZ this weekend so tonight’s project is to rig a small trailer to get there. Please keep the criticism light.....
    The trailer is an old and faithful Harbor Freight https://www.harborfreight.com/1090-l...ler-62645.html
    On top of the thin but surprisingly sturdy frame will be the plank... plank is 1/2 plywood 8’ long 11.5” wide, screwed to one side (bottom) is an 8’ long 2x10 next to a 2x8, screwed to the top is two 8’ 2x4s with a slight taper so the tires rests snugly between them (down the center).
    I used this plank several years ago to haul the bike from AZ to KS in the back of a ford ranger (a pleasant experience).... glad I kept it.
    I’ve got pics but it’s easier not to add them.
    I’m off to HF to get a wheel chock before it closes and I get a headache.
    So.... any science on this one?
    Ride safe or stay home~
    Phil
    ~ride safe or stay home
    As I recall, it's a little to the rear of the kickstand. But then it would change based on if you have a windshield, fairing, speakers, full gas tank, saddle bags, and stock exhaust. What I did was lift the trailer tongue a little with the bike on it to see when it was balanced, then moved it forward six inches. But that was in part since I was using a heavy Condor chock in the front which weighs about 50# and was bolted to an 8'X3' board.
    Or you can put a jack under the bike on the ground and see where the balance point is when front and rear tires are suspended.
      I do not know the answer, but when I use my bike jack, it is about the middle of the engine. I have a windshield, engine guard and my floor boards are moved forward.
      Started by Herrindude, 3 hours ago
      Started by Doc_V, 1 day ago
      Started by Thee_masonator, 19 hours ago
      Started by Jaybo, 19 hours ago
      Last Post fastjohnny
      Started by Pressure, 1 day ago
      Last Post Herrindude
      Started by Bricejevinn, 4 weeks ago
      211 responses
      126 responses
      Started by ItBeMe, 20 hours ago
      Started by EnergyGuy, 4 days ago
      Started by roadiemort, 12-29-2019, 01:18 PM
      Started by MikeyC, 04-02-2018, 12:51 PM
      Started by millwrong, 5 days ago
      Started by Jaybo, 2 weeks ago
      Started by Milkman, 6 days ago
      Started by cike, 4 days ago
