2006 starter assembly
  • 2006 starter assembly
    I can't find anywhere to pin the brushes in, usually there a pinhole where a tooth pick or paper clip can be used to hold the brushes but this one got me stumped. A bottle cap maybe?
    i use pieces of wooden clothespins cut/modified with a set of dikes , so when u push them in they hold the brush springs in so the armature can be installed. carefully inspect the brush plates first. they are known to hairline crack, the brass part where there are 90 degree bends. usually if they are cracked, they will crumble in your hand.
      Brush plates? I will take a closer look, do you mean the holder?
        I used plastic toothpicks .nits kind of a pain but doable
          The the brushes sit on a brush plate, the brush plate holds all four brushes and the little boxes that hold them in place and the springs that push them inward
            Use square pieces of clothes pins cut with a dyke to hold the spring you'll figure it out after you play with it I have the wood on the outside of the square box outboard end of the springbox and that little corner
              You have to get them brushes all the way tucked in almost
                Don't forget to line up a little alignment marks on the housing made by Yamaha they're black and hard to see don't get it 180° out
                Started by Herrindude, 3 hours ago
                Started by Doc_V, 1 day ago
                Started by Thee_masonator, 19 hours ago
                Started by Jaybo, 19 hours ago
                Last Post fastjohnny
                Started by Pressure, 1 day ago
                Last Post Herrindude
                Started by Bricejevinn, 4 weeks ago
                211 responses
                126 responses
                Started by ItBeMe, 20 hours ago
                Started by EnergyGuy, 4 days ago
                Started by roadiemort, 12-29-2019, 01:18 PM
                Started by MikeyC, 04-02-2018, 12:51 PM
                Started by millwrong, 5 days ago
                Started by Jaybo, 2 weeks ago
                Started by Milkman, 6 days ago
                Started by cike, 4 days ago
