Head light and passing lamb Advice
  • Head light and passing lamb Advice
    I am thinking of upgrading my head light and passing lamp bulbs to led lighting. can I just swap the bulbs out? or are they plug and play or do you need to make modifications for them to work. I have a 2007 Roadstar Silverado 1700. its all stock. Any recommendation on the type of bulbs to use?
    By all means you will not regret this upgrade. The ones I got from amazon are complete replacement for the main headlight and passing lamps. The headlight was plug and go, the passing lamps had to be wired because there is not enough room for the wiring harness. You will have to remove the switch on the left side passing light for the new one to fit.
      https://www.amazon.com/Motorcycle-He...ype=motorcycle
        These are the ones I installed on my 07 roadstar Silverado
          I noticed in the amazon ad it showed mode 1 as "DLR", i'm assuming that is DayLight Running mode. Does the light sustem use the factory switch controls? If so, how do you change from DLR to low beam? I'd much rather have the full headlight on all the time, not the DLR.
          Thanks
            it uses the factory handle bar switch. on low the halo and headlight is on together and my passing lights. on high beam the halo goes off. the directions are pretty crappy but I see there are more videos on amazon if you scroll down on the product page, I believe it was a yellow wir I tapped in the headlight power wire to make the halo work.
            Started by Father Pobasturd, 5 hours ago
            Started by Dick M, 16 hours ago
            Started by Eazy1, 2 days ago
            Started by JoeBloShmo, 20 hours ago
            864 responses
            Started by Jeaston, 1 day ago
            Started by MikeyC, 07-20-2019, 12:09 AM
            47 responses
            Last Post FDRUCaptain
            Started by NCB, 5 days ago
            Started by Wonky1, 2 days ago
            Last Post Wonky1
            by Wonky1
            Started by Pauli466, 4 weeks ago
            Last Post fastjohnny
            Started by MCMLXXIV, 07-25-2019, 01:08 PM
            Last Post K. Clayton
