Hi guys I'm ready for the cool temps. Well let's begin, I tore the carb off my 99 1600xv because of a backfire issue and not knowing whether the previous owner changed the jets when he installed a bak and removed the ais system. Plus I removed the old exhaust and installed a nice Cobra swept exhaust system. Also new fuel pump (Ebay special). 37.5 jet and a barons jet kit. Also new diaphragm and cover. Well tried to start and fuel shot everywhere. I think I replaced the needle valve. Or maybe the cheap fuel pump to much pressure. Maybe time to go pumpless. Any suggestions??? Wat involved in going pumpless?
Comedy of errors
going pumpless is OK but won't resolve the issue that you have right now. your float is sticking for some reason. check to see if the screw that holds the float pin in is somehow making the float stick open.
Did your aftermarket pump have a pump pressure spec with it? Did it claim to be for a R* and come from a reputable store like JP cycle?
No it came from Ebay. Didn't find out till after receiving it that have to beware of certain knockoffs. Think I still have the old one. May have to try to pick up another old one still in working order. Was trying to replace sum things before they break down. Have to rethink that idea from this point on.
If the old one wasn't broke put it back on. It would be an easy test to see if the new pump is the wrong pressure. and blowing fuel by the float valve. If it still leaks fuel you will have to go back into the carb to see what is happening in there.
- 1 like
Ok. Popped the new one in. Have 2 o-rings left. Will check manual to see if I can locate where they might go. Hope to get back this weekend. Only a few more weeks left here in Maryland for crabs. Just got off call so got to try to have a few. Thanks again
SHE LIVES!!!!!! Finally got it started. No leaking fuel so far and no backfiring so far. I did notice that after pushing the choke in the idle didn't change. I did do a rebuild kit on the choke. Anyone dealt with this problem?
1 hour ago
Started by K. Clayton, 3 hours ago
1 hour ago
Started by JD64k, 1 hour ago
by JD64k
1 hour ago
Started by bencadenbach, 1 week ago
by Lifeguard
2 hours ago
Started by Pauli466, 5 hours ago
3 hours ago
Started by Lucky, 4 weeks ago
11 hours ago
829 responses
Started by rox, 1 day ago
Started by Ironman, 3 days ago
Started by gunner308, 02-14-2018, 03:53 PM
Started by JoeBloShmo, 1 week ago
by cike
Started by Vicious, 2 days ago
Started by Cubo55, 2 days ago
Started by cike, 2 weeks ago
by Bikerron
Started by Ironman, 6 days ago
Started by cike, 6 days ago
Started by Kenkaman, 1 week ago
by bencadenbach
Started by brianmac, 1 week ago
by Spydr
