Non Roadstar-bike overheating problem.
  • Non Roadstar-bike overheating problem.
    Figured there’s some good mechanical experience around here so it’s worth a stab.
    Bike in question is a 2006 Yamaha R1.
    Little background. Trying to get some good old fashioned forum help for this issue. Started recently overheating while riding. Ambient temperatures not extreme (70-85°F only). Radiator fans are working properly. Radiator is clean. Installed a new thermostat and took it for a ride. Seemed to work fine for about 5-10 miles (coolant temps reading 180°F or lower). Then, coolant temps started to rise above 200°F. This while cruising along at 70mph in top gear (around 5300RPM). Virtually no load on the engine (flat Michigan ground). Started seeing coolant temps above 230°F. Only way I could get them to start dropping closer to 200°F was to downshift and get the RPM’s up (7000-8000). Temps would go back down closer to 200°F which is still hotter than normal. Coolant boiling over out of the overflow when parked right after this. I originally replaced the thermostat due to the exact same issues. Obviously that wasn’t the problem but it was worth a try.
    I rebuilt this engine about 5 years ago. Cooling system has only ever had distilled water+water wetter or Engine Ice. When I say rebuilt, I mean completely. Split cases, new crankshaft, new plane bearings, piston rings, all new valves in #3 cylinder, new piston in #3, machine shop checked the head and cylinders for spec, the whole deal. Machine shop balanced all 4 piston/connecting rod assemblies. Very meticulous. All parts were washed several times in a parts washer. All OEM Yamaha parts used only. All gaskets, followed the service manual to the letter, etc. Bike has ran perfect since then for about 3,000 miles. 500-700 miles of that is track days at top third of advanced level (just to give an idea-it’s been taken care of very well but also ridden hard).
    Engine Ice came out of bike looking exactly like it does in the brand new container (yesterday, when doing the thermostat replacement). No debris, sludge, discoloring, etc. Normal street riding and this bike has always run coolant temps around 170-180°F until this problem.
    All that being said, the above facts point me to a water pump that is not pumping coolant like it should. Maybe still circulating but at a severely reduced rate. I’m waiting to take the bike apart until I do more research, see some opinions here, etc. I have all the tools and knowledge to take the thing apart and repair it myself. Also have the heated/air conditioned shop to do it in. Colder temps are coming fast here so this may ultimately be a winter project but I’d like to start getting in front of it soon.
    What say ye?
    My first thought was a blockage somewhere in the system.
    Your water pump theory sounds very likely to me.
    Can't wait to see what the experts think about this.
      One thing easy to check is Rad pressure cap. Also is that a system that needs to filled with a coolant AirEvac tool to make sure that there is no air trapped in the system? You may be correct on the water pump also. A bad head gasket in a coolant jacket will pressurize the cooling system and sometime to the point of blowing coolant out of the radiator (cap off) and you can actually see the piston pulse as it is blowing out.
      https://youtu.be/9GbxhF9bBxE
        Anything electronic (sensor) involved in the coolant process? Tells fans when to kick on etc? If not pull water pump and inspect in would think. I rebuilt a leaky water pump on a liquid cooled 1300 Royal Star and it definitely ran cooler afterwards.
          Davej:
          No special tools needed to fill system. It’s a similar setup to any old car you can think of. Radiator, water pump, thermostat, radiator cap with an overflow tube that goes to an overflow reservoir. Nothing in service manual says anything about filling it (other than to just fill it). Plus, I’ve drained and filled the system and ridden for a few thousand miles with no issues.
          Lugnut:
          One coolant temperature sensor. The temperature is displayed on the dash when the bike is on. Fans come on at 220°F and then back off at 212°F (which is exactly what they’re supposed to do). Sensor appears to be working properly.
            Water pump and oil pump are one unit inside the oil pan. That’s the reason I’m poking around first. If I have to remove it, so be it. But if I don’t have to, I’d rather not, ha ha. Big job.
              Did you run the engine with the rad cap off to bleed the air from the system? Does the rad cap look like the highest point in the system? You may need to jack up the front end only to make the rad cap the highest point. Can you see any coolant flow in the rad with the cap off?
                You did check the oil, right, to make sure there's no water in it? Some water cooled BMW's drive the water and oil pump off a common shaft. I had one that the shaft seal failed and it pumped water into the oil, but no oil into the water. Made a real mess, and the bike ran hot.
                  Yes to all. It’s the highest point for sure. Ran it with the cap off. Also rode it, let it cool down and topped it off. It’s not a coolant level problem. Have drained and filled this system several times with no issues. Good question though.
                  However, even if it is moving around in there, that doesn’t mean the water pump is pumping effectively.
                    Yes and the oil is fine. Yamaha engineers installed a coolant weep hole/tube in the water pump assembly that goes down thru the bottom of the oil pan. If the seals in the water pump go bad, it doesn’t contaminate the oil. It goes out the weep hole. Pretty ingenious design for an eventual failure they worked in there if you ask me.
                      Damn that blue 2020 R1 looks damn sexy. I won’t post a pic but google it. Damn it’s sweet!
                      My 2006 is still pure sex but this has me thinking...
                      Onwards and upwards...
                        Sounds like the water pump needs to come out and apart. Just googled a parts break down. 5 bucks on a sheared roll pin or a loose impeller nut.
                          Probably right. Although if I go thru all that to remove it I’ll probably just replace the whole assembly. Depends on what it looks like I suppose.
                          Needs a new rotor. Maybe a stator and a clutch job also for prevention. Will be a winter project probably.
                          Started by Ironman, 12-09-2019, 10:28 AM
                          Started by Jaybo, 1 week ago
                          196 responses
                          113 responses
                          Last Post LeLimoMan
                          Last Post JimK
                          by JimK
                          Started by millwrong, 2 days ago
                          Started by cike, 2 days ago
                          Started by Milkman, 4 days ago
                          Last Post Milkman
                          by Milkman
                          Last Post TerryInFlorida
                          Started by NCB, 2 days ago
                          Started by WarPig, 3 days ago
                          Started by Michael72, 5 days ago
                          Started by Doc_V, 2 weeks ago
                          Started by cike, 2 weeks ago
                          Last Post cike
                          by cike
                          Started by Pauli466, 5 days ago
                          Started by Doc_V, 5 days ago
