I didn't notice in any discussions about going pumpless (I might have missed it), but, when you switch to going pumpless, do you have to turn off the petcock when you turn the bike off, or should the float valve suffice for preventing fuel overflow?
Pumpless question
No Sir. No need to turn off the petcock anymore once you go pumpless, *Unless* you just want the extra security.
It is recommended that you upgrade to a larger float needle/seat set for better gas flow.
With that new needle/seat your float should totally shut off the fuel flow into the bowl.
I never leave a gravity flow system open. I shut mine off every time it’s going to sit for long.
I still run the pump, but if i was pump-less I'd turn the fuel off every time I turned the engine off. I used to own a Kawasaki vulcan 800 and they were notorious for float valve sticking open. What made matters worse is it used a vaccum shut off petcock that was a piss pour design (Kawasaki redesigned them at some point) and when the float valve stuck open it would empty the entire tank down into that engine. it made a royal mess. I find the pump to be very good protection against that happening. If the float valve sticks open or get a piece of junk in it all that gets dumped into the engine is whats in the bowl and fuel line.
New Subject on Pumpless : Last two times out after stopping for a while , I restart with no problem but , after taking off I get a major Sputtering and it dies like it just ran out of gas . After sitting a few it restarts and goes on down the road. Also had this Sputter - Die act happen once when opening up the throttle . What could be the problem ? I simply removed my pump and ran a 5/16 fuel line with a filter. Has worked great for 3-4 tanks and now this .
Hmmm, look for a trap in the fuel line between the jugs where it traps air, the heat in there could cause a vapor lock type issue, make sure fuel line is not against one of the jugs. My guess only. More knowledgeable people will chime in.It's not that life is so short, it's just that you're dead for so long.---unknown.
in florida sun, black color, hot , not pumpless, i noticed without shutting off cock, oil always had a gasoline smell. so it was getting in there when u least expect it, plus i have a gas water heater in my garage.
I used to have that very problem... the solution for me was simply this... I would leave gas ON during the entire time of my ride, and would only shut it OFF when I parked it back at home. Just stopping during the ride... leave the gas on.
Hi , if you Ride hard , you may want to upgrade to the Yamaha 3.0 Needle and seat , it’s a direct replacement . I think the 3.0 was originally for a Yamaha Wolverine ?
Started by JBones, 2 days ago
by JBones
2 hours ago
Fuel relay
by 2 dogs
Started by 2 dogs, 8 hours ago
by Jclevesque
5 hours ago
Started by MrG, 08-30-2020, 03:09 PM
5 hours ago
Started by Smokescreens, 3 days ago
by Lifeguard
13 hours ago
Started by matthewrosspeebles, 1 day ago
16 hours ago
Started by Blackbeard, 1 week ago
16 hours ago
Started by EnergyGuy, 4 days ago
17 hours ago
17 hours ago
Started by Hank1988, 4 days ago
by Hank1988
by Pauli466
Started by LDofDC, 4 weeks ago
81 responses
Started by Dan58, 3 days ago
by DEEPHATE
by EP Roadie
Started by Jclevesque, 06-02-2018, 11:19 AM
Started by choppa, 6 days ago
by JBones
Started by Chooch, 12-05-2020, 10:49 PM
by JBones
by Pauli466
Started by MrSinister, 12-06-2020, 08:54 AM
by MrSinister
