A year together
  • A year together
    I bought my 04 roadie about a year ago with 47500 miles on it for about 1200. Since then I've put about 4500 miles on it under the Arizona sun.
    It had been sitting under a tarp in the back yard for about 2 years when I bought it. It had one owner, but he wasn't so great about maintenance. He changed the oil and that's about it. She needed some love.
    In the last year I've (in order):
    Fresh battery
    New stator
    New regulator
    Oil change (synthetic AMS oil)
    Carb rebuild (Baron's)
    New K&N air filter
    Maxair Stainless choke (which I really like)
    New tires (Commander II)
    New rear rotor
    New brake pads all around
    Fresh brake fluid
    Memphis shades windshield
    Fresh clutch/throttle/idle cables (Barnett stainless)
    New grips
    2nd oil change
    Fresh gear oil
    I feel like everything that NEEDS to be done is done... now I'm getting into the territory of things I WANT done.
    A roadwing and racetechs are on my wishlist. As are braided stainless brake lines.
    Is there anything else I should keep an eye on maintenance wise? I see recent posts about the pulley nut, do I need to get in there and inspect?
    I would definitely make sure it's tight. I bought an 05 this year with 12000 miles on it. Reading on here about the pulley nut I checked mine and it was loose. Had to buy a new pulley.
      Check/regrease/replace steering head bearings and wheel bearings
      check swing arm bearings
      fork oil change
      lube clutch and throttle cables
      new spark plugs and fuel filter
      check belt tension and rear wheel alignment
      check pulley nut and grease rolless for drive belt
      AIS Delete if not already done
      Started by Herrindude, 8 hours ago
      Started by Lucky, 2 weeks ago
      46 responses
      Started by jeckert, 01-13-2019, 08:54 PM
      77 responses
      Last Post highvoltage
      741 responses
      Started by J89k, 1 day ago
      Started by Danman1995, 5 days ago
      Started by Doc_V, 04-10-2019, 10:26 AM
      Started by Blackcloud12, 5 days ago
      Started by Penguin, 3 days ago
      Last Post Penguin
      by Penguin
      Started by J89k, 5 days ago
      Started by Shores, 3 days ago
      Started by JD64k, 2 days ago
      Started by spideydesigns, 3 days ago
      Started by dlist, 2 weeks ago
      Last Post dlist
      by dlist
      Last Post Panayiotis Chrysanthou
      Started by rooreeves, 1 week ago
      Last Post rooreeves
      Started by cromwell, 1 week ago
      Last Post cromwell
      Started by Qkenuf4u, 02-22-2019, 05:57 PM
      74 responses
