Sounds like I'm shooting at Ducks!! Is the Coasting Enricher adjustable.
High RPM deceleration back fire
if it is a carb bike check the vacuum line rubber cap on the top of the intake manifold to see if it fell off or is damaged. replace it when you see that it is and the issue will go away. It is very common that the rubber vacuum caps dry rot and cause a vacuum leak and a lean pop on decel.
Backfiring is caused by a lean condition OR air leak.
You can adjust the air pilot screw and check for air leaks.
It can be exhaust leaking between the cylinder head and the exhaust pipe or air intake leak. NOT the air filter.
Jetting can be incorrect if you have not changed the jetting and you have a non stock air filter and non stock exhaust system.
You didn't mention what you have for an exhaust system... installing any aftermarket system requires a little finesse to make sure all joints/connections are well sealed, and don't permit any cold, outside air leakage.
yase, but did u say backfire out carb or exhaust? assuming exhaust, assuming this just started, no changes, bike didnt sit for long time. maybe eddie murphy stuck a banana in your tailpipe.
critters in air filter, leaky intake or exhaust at the head..........
2 hours ago
Started by ItBeMe, 6 days ago
by Bikerron
4 hours ago
Started by Kenkaman, 21 hours ago
by texasscott1
9 hours ago
Started by Parhamj, 15 hours ago
by Bikerron
10 hours ago
Started by Pauli466, 13 hours ago
by Bikerron
11 hours ago
Started by Ret HPD, 1 day ago
14 hours ago
Started by gold03, 1 week ago
by gold03
16 hours ago
Started by Lucky, 4 days ago
18 hours ago
Started by Father Pobasturd, 21 hours ago
by Spydr
18 hours ago
Started by jjvw, 1 week ago
by jjvw
Started by GNR10, 1 day ago
by Gizmoinok
Started by cap-tech, 3 weeks ago
by Vicious
Started by GNR10, 1 week ago
Started by Jaybo, 4 days ago
by jd750ace
Started by oldbw, 1 week ago
by oldbw
4 days ago
Started by Pauli466, 5 days ago
4 days ago
Started by cike, 1 week ago
4 days ago
Started by Ret HPD, 2 weeks ago
by Ret HPD
4 days ago
4 days ago
