Oil change time
  • highvoltage
    Thanks Brad_G. Learn soothing new everyday
  • Brad_G
    Yeah wife's don't often see much humor when things go from the kitchen to garage.
  • fastjohnny
    That's a good idea with the "redneck funnel". I changed it once while on my HF stand....wat a f&%#ing mess! Since that I've been putting a 4 x 4 under the stand to make it level-ish. I found a big flat Tupperware container in the cupboard and drain it into that. Wife found out and was really pissed off.....maybe that's why she's my ex.....well among other things I guess LOL.
  • Brad_G
    On my HF jack style lift I can get to the plugs. Last time I changed it I used an old license plate and bent the end to hook on the bike frame. It created a funnel to my bucket. Not the most ideal but worked without incident.
  • Brad_G
    highvoltage I think the "ride on" lift is the table style instead of the jack under the frame.
  • Chrominator
    On my lift I can get to BOTH PLUGS np
    4 out 4 in
  • highvoltage
    I've never had a problem getting an oil pan under the bike while on the lift. If you position the lift on the right place, it will give you acces to both plugs. I use a lift that I purchased a few years back. It is similar to the HF lift. What is a ride-on lift ?
  • LeLimoMan
    Throw 2-4oz of Seafoam in the oil and take it for a ride. Then do your oil change. Oil will come out BLACK! I use Mobil 1 V-Twin oil. Use an OEM filter if available, otherwise NAPA/Wix gold. (Stay away from Fram Filters).
  • Questcap
    Well, once it's on a lift, how do you get a pan under it to catch the oil? The lift interferes with everything... usually one of the plugs becomes inaccessible, too... or are you talking a ride-on lift with wheel lock?
  • highvoltage
    I place mine on the bike lift. I always change the oil after I ride for at least one hour. Always change the filter and 4 qts out, 4 qts in.
  • Zamman
    Originally posted by ItBeMe View Post
    I just change it no messing around Lol Click image for larger version
    Nice
  • ItBeMe
  • Questcap
    I leave mine on its side stand, but, so that my Snap-On thinwall 17 mm wrench will fit on the head of the front plug, and so that the large kitty litter pan will easily slide under, without interference, I tip the bike and place a paver brick, fat-side down, under the side stand for that extra 2" or so that makes the extra room for it all to happen. (Oh, and I use Amsoil 10w-40 for Metric bikes, shhhhh! )
    Sometimes I do it hot for a quick change, or sometimes I do it cold, and just leave the plugs out and let it weep overnight or longer.
    Side stand ...loosen and remove drain plugs...and use some wood (2×4 and 1x4) under the side stand to make it more level while draining...
  • LDofDC
    I use three blocks 1and a half inches thick. One under each wheel and one under the kick stand. Drain pan fits and regular length wrench fits under. 4 quarts out 4 quarts in.
  • Zamman
    started a topic Oil change time
    Oil change time
    Now I’m sure this topic has been discussed to death.... but.... is it best to drain/ change the oil on the side stand or on a bike lift so it’s upright??
Started by Pauli466, 1 day ago
Started by NCB, 3 days ago
Last Post fastjohnny
Started by Father Pobasturd, 5 days ago
45 responses
Last Post tapeit59
Started by MCMLXXIV, 07-25-2019, 01:08 PM
Last Post K. Clayton
Started by Pauli466, 4 days ago
Started by p birk, 17 hours ago
Started by Jaybo, 3 days ago
Last Post Questcap
Started by thunderace4, 10-19-2019, 12:34 PM
Last Post thunderace4
Started by Herrindude, 1 day ago
Started by K. Clayton, 4 weeks ago
Started by cromwell, 3 days ago
Started by Troyf19, 3 days ago
Last Post Questcap
Started by Ypsilonn, 02-24-2018, 02:22 AM
93 responses
Last Post Ypsilonn
Started by NCB, 1 week ago
Started by Father Pobasturd, 05-24-2019, 03:51 PM
859 responses
Last Post JoeBloShmo
