Oil change time
  • Oil change time
    Now I’m sure this topic has been discussed to death.... but.... is it best to drain/ change the oil on the side stand or on a bike lift so it’s upright??
    2004 RS Silverado (can’t even get the radio working)
    I use three blocks 1and a half inches thick. One under each wheel and one under the kick stand. Drain pan fits and regular length wrench fits under. 4 quarts out 4 quarts in.
      Side stand ...loosen and remove drain plugs...and use some wood (2×4 and 1x4) under the side stand to make it more level while draining...
        I leave mine on its side stand, but, so that my Snap-On thinwall 17 mm wrench will fit on the head of the front plug, and so that the large kitty litter pan will easily slide under, without interference, I tip the bike and place a paver brick, fat-side down, under the side stand for that extra 2" or so that makes the extra room for it all to happen. (Oh, and I use Amsoil 10w-40 for Metric bikes, shhhhh! )
        Sometimes I do it hot for a quick change, or sometimes I do it cold, and just leave the plugs out and let it weep overnight or longer.
          I just change it no messing around Lol Click image for larger version
            Nice
              I place mine on the bike lift. I always change the oil after I ride for at least one hour. Always change the filter and 4 qts out, 4 qts in.
              I will not apologize for being white, being straight or for loving this country.
              • highvoltage
                highvoltage commented
                I've never had a problem getting an oil pan under the bike while on the lift. If you position the lift on the right place, it will give you acces to both plugs. I use a lift that I purchased a few years back. It is similar to the HF lift. What is a ride-on lift ?
                highvoltage I think the "ride on" lift is the table style instead of the jack under the frame.
              • highvoltage
                Thanks Brad_G. Learn soothing new everyday
              Throw 2-4oz of Seafoam in the oil and take it for a ride. Then do your oil change. Oil will come out BLACK! I use Mobil 1 V-Twin oil. Use an OEM filter if available, otherwise NAPA/Wix gold. (Stay away from Fram Filters).
                On my lift I can get to BOTH PLUGS np
                4 out 4 in
                  On my HF jack style lift I can get to the plugs. Last time I changed it I used an old license plate and bent the end to hook on the bike frame. It created a funnel to my bucket. Not the most ideal but worked without incident.
                  • fastjohnny
                    fastjohnny commented
                    That's a good idea with the "redneck funnel". I changed it once while on my HF stand....wat a f&%#ing mess! Since that I've been putting a 4 x 4 under the stand to make it level-ish. I found a big flat Tupperware container in the cupboard and drain it into that. Wife found out and was really pissed off.....maybe that's why she's my ex.....well among other things I guess LOL.
                    Yeah wife's don't often see much humor when things go from the kitchen to garage.
                Started by JoeBloShmo, 19 hours ago
                Started by TEXenvy, 6 days ago
                Started by 75kona, 15 hours ago
                1,536 responses
                Started by TataMichas, 2 days ago
                Started by SPislanderATX, 2 days ago
                Started by GreasySam, 10-03-2019, 05:13 AM
                Last Post GreasySam
                Started by ctkog, 1 week ago
                Last Post GreasySam
                Started by DDsRS, 1 day ago
                Last Post Wonky1
                by Wonky1
                62 responses
                Last Post Wonky1
                by Wonky1
                Started by petr.hw, 2 days ago
                Started by tapeit59, 3 weeks ago
                Started by badger2078, 2 days ago
                Started by Bricejevinn, 2 days ago
                Last Post Bricejevinn
                Started by petr.hw, 3 days ago
