Transfer Case Filler hole and weep hole access
  • Transfer Case Filler hole and weep hole access
    Sorry for the long title. I am looking at after market exhausts for my 06 and what I am looking at (Cobra Power Pro) appears to block access to the filler and weep holes in the transfer case. Does anyone know if this is the case or is the pipe far enough off the bike to get tools and a funnel in there?
    Better to have questions you can’t answer than answers you can’t question
    It's pretty common with a lot of pipes that you have to remove the rear exhaust pipe to get to the caps and fill the case. If you get new pipes it wouldn't hurt to change your fluid before you install them.
      I've noticed recently that I seem to be experiencing a bit of weepage in this area. Replace copper gasket?
        Thanks Doc. Is what it is I guess. So..... where do you stand on using never seize on exhaust studs?
          I've personally never used it, but it would help prevent corrosion. Mine are rusted. I'd use the hi temp stuff.
            Yea, if the pipes need to come off, and you're going to change that gear oil with any frequency at all... Never-Seize is a real good idea... and, as Doc suggested, go with the Hi-Temp kind! You don't want them rusting or seizing!!! We've read of more than just a few broken stud accounts here.........
            • 2time
              2time commented
              Thanks Questcap. I change the transfer case oil once a year so I guess the exhaust system would be coming off as well. I’m no stranger to easy outs, heli coils and other damage control but I’d rather not go there. When i made the OP I was thinking the bike had suds that came out of the cylinder head. But now that i have checked it looks like an allan head bolt that threads into the cylinder head.
            • Questcap
              Questcap commented
              No, no.... We've got studs with Allen-headed nuts that screw onto them. The biggest mistake most make is to over-tighten them. Factory spec is for 11 ft. lb., which isn't a whole lot, but most go well past that. The flanges on a lot of aftermarket pipes will bend when over tightened... when that happens, the studs splay outward some, and then you've got a problem getting the pipes off, as the flanges don't want to slip off the splayed studs.
            • 2time
              2time commented
              Great info thanks Questcap
          Started by GNR10, 1 day ago
          Started by brianmac, 2 hours ago
          Started by Pauli466, 18 hours ago
          Started by jjvw, 1 week ago
          Started by roadiemort, 7 hours ago
          Started by ItBeMe, 1 week ago
          Last Post texasscott1
          Started by Parhamj, 20 hours ago
          Started by Ret HPD, 1 day ago
          Started by gold03, 1 week ago
          Last Post gold03
          by gold03
          Started by Lucky, 4 days ago
          Last Post Spydr
          by Spydr
          Started by cap-tech, 3 weeks ago
          Last Post Vicious
          by Vicious
          Started by GNR10, 1 week ago
          Started by Jaybo, 4 days ago
          Started by oldbw, 1 week ago
          Last Post oldbw
          by oldbw
          Started by Pauli466, 5 days ago
          Started by cike, 1 week ago
          Started by Ret HPD, 2 weeks ago
          Last Post Ret HPD
          by Ret HPD
