Flagging spam
if you see a spam post, don't reply or comment on it. Just flag it. We get those flag reports and take action. That action is pretty simple. If the post is obviously spam we delete and then check few boxes to delete all other posts by that user and ban them permanently. If the post is questionable as spam then we can suspend the user and then send them a message to work it out.
So when it doubt - Flag The Post
See more
See less
Speedo repair.
  • Speedo repair.
    The needle fell off my speed o meter. Can it be opened up some way so I can put the needle back on? Looks like it just came off the shaft that drives it.
    Yep. It happened on my old bike. Just remove the screws on the back of the plastic cover. Test the needle before you put it back together. Don't push it all the way on until you make sure it's aligned properly. Getting the alignment correct can be a little tricky because the dial does a test sweep every time you turn the key on. The first time I tried, I just put the needle next to the little post at zero MPH, but when I turned the key, after the needle did it's sweep, it stopped at 10mph and read +10 mph after that. So just plug it in and turn key before putting the cover back on. Test it a few times, because it might work the first time, and then later get stuck at a higher level. I Hope this makes sense.
      It does make sense, I have had it do that a few times and I just ignore it then after awhile it goes back to normal. Thanks for the info, I can look at it tonight.
        Glad you gave me the heads up about testing before putting back together, took 3 or 4 tries but it was an easy fix. Thank you
        Started by TwitchBDHR, 4 hours ago
        Started by Panayiotis Chrysanthou, 1 hour ago
        Started by Jed Milhorne, 3 days ago
        Last Post Panayiotis Chrysanthou
        Started by roadiemort, 8 hours ago
        Started by jcova58, 8 hours ago
        627 responses
        Started by Deerkiller, 2 days ago
        Started by Azuqui, 1 week ago
        Last Post Azuqui
        by Azuqui
        Started by Bikerron, 1 day ago
        Started by Kevin Di, 1 day ago
        Last Post Kevin Di
        Started by Jclevesque, 4 days ago
        Started by Jed Milhorne, 5 days ago
        Started by BubbaKahuna, 01-26-2019, 01:56 PM
        90 responses
        Last Post AreikUSA
        Started by Overkill jones, 3 days ago
        Started by J89k, 1 day ago
        99 responses
        Started by Brian Schenk, 06-20-2019, 09:08 AM
        Last Post Jed Milhorne
        Started by zulater1990, 3 days ago
        Last Post zulater1990
