Passing/Fog Lights
  • Passing/Fog Lights
    Where can I find (as close to stock looking) fog / passing lights for my Roadie? Or stock ones? I don't want the ugly Chinese ones on ebay.
    The ones in the picture are HD. Won't work on my bike but looking for this kind of look.
    Also looking for headlight and fog light visors.
    You can buy the bracket, housings and hardware new or maybe somebody here has a used one you can buy.
    Peace,
    (But you can call me Joe)
      I think I still have the ones I took off my 04 but they don't have the turn signals. Your signal may work in it. If your interested I look for them.
        I have the Adjure blue dot lamps in mine, headlight and passing lamps. replaced the standard bulbs with
        leds. Pretty bright, but I still want some low mount LED spots for fog. My passing lights are aimed out to each side a bit so people in intersections see me.
        Oh yeah, and a linky
          Jay, no problem with the fit of those lights? I ordered some that said they were for a 41/2 light, but were really 41/4. Yamaha changed the size around 07 to the smaller size. But when I ordered my replacements Driving lights they ended up being the larger size.
            I am definitely interested in them. I will make my existing turn signals work with them.
            PM'd you.
            Thank you.
              No, not at all on my 2000 - not sure if they are original or not, I did replace the cracked mounting bar last season. Here is a pic of them....
                Any chance of a angled pic with the lights on Jaybo? I’m curious if the blue dot glows at all
                  It does glow some, and I've left the place where I am working on it but I might get back over there tomorrow. If not it may be Wednesday or Friday before I am back I could.
                    When you get a minute would you measure the outside of the front of the bucket at it's widest point. That is where my problem was. The bulbs were to small and would fall into the bucket.
                    • Jaybo
                      Jaybo commented
                      Sure thing, It may not be until Wednesday unless I run over there today.
                    No hurry, thanks!
                      Here ya go, shows the glow does the same on the headlight too
                        mine is 4.5" too and the bulbs are just over 4.25" They sit against the edge of the bucket no problem. Tighten down with the ring and are quite solid. Maybe you have some off brand buckets?
                          Thanks, wanted to make sure that these would fit. My bulb are 4 1/8 . Wrong bulbs. The pic you put up of the lights on did not show up. Would like to see what they look like running.
                            Mine are actual Adjure units with H3 LED bulbs that are replaceable. Maybe some creative electrical tape wrapping could fix yours? Anyway, I see my pic up there but I'll post a couple more:
Name:	Adjure headlight.jpg
                            The headlight and R passing light
Name:	adjure passing light.jpg
                            close up of the L pas lamp.
                              I mounted those exact HD lights & signals on my Roadstar.
                              I used a Yamaha spotlight mounting bar & rewired the HD lights into the stock harness.
                              • BubbaKahuna
                                BubbaKahuna commented
                                I got the entire setup plus some other HD take-off parts on Craigslist for $75.
                                The Howitzer tips in the box alone brought $50 on eBay & the fender bling brought $25.
                                So basically I have nothing into the lights but my time & the cost of the Yamaha bracket.
                                I still have the HD bracket I can sell for a couple bucks.
                              Who Sez they won't work on your bike???
                                ^^^^^^^^^^^^^^^^^^^^^^^^^^ Yup.
                                  The exterior of the bucket on mine is 5" at the front. Yamaha Part #STR-4NK35-10-01 They changed the size sometime. The older nnumber is #STR-4NK35-10-00. Just my luck!
                                  Started by Doc_V, 1 day ago
                                  Started by LeLimoMan, 11 hours ago
                                  Last Post highvoltage
                                  Started by Shacky, 3 hours ago
                                  Last Post Shacky
                                  by Shacky
                                  87 responses
                                  Started by dunl, 10-08-2018, 05:48 PM
                                  Started by gillis.jordan, 4 hours ago
                                  Started by Cashman240, 2 weeks ago
                                  Last Post Chrominator
                                  Started by Taz1700, 2 days ago
                                  Started by zingpow, 1 hour ago
                                  Last Post zingpow
                                  by zingpow
                                  116 responses
                                  Last Post JD64k
                                  by JD64k
                                  Started by Jaskin71, 14 hours ago
                                  Started by El_Mipo, 11-02-2018, 11:15 AM
                                  52 responses
                                  Started by Ronijoe, 8 hours ago
                                  Last Post Ronijoe
                                  by Ronijoe
                                  Started by Doc_V, 10 hours ago
                                  Started by 75kona, 7 hours ago
                                  Last Post 75kona
                                  by 75kona
                                  Started by zingpow, 5 days ago
                                  Last Post zingpow
                                  by zingpow
                                  Started by Lucky, 9 hours ago
                                  Last Post texasscott1
                                  Started by Jaybo, 11 hours ago
                                  Started by zingpow, 1 week ago
                                  Last Post zingpow
                                  by zingpow
                                  Started by scooter68, 2 days ago
                                  Last Post Jaskin71
