Flagging spam
if you see a spam post, don't reply or comment on it. Just flag it. We get those flag reports and take action. That action is pretty simple. If the post is obviously spam we delete and then check few boxes to delete all other posts by that user and ban them permanently. If the post is questionable as spam then we can suspend the user and then send them a message to work it out.
So when it doubt - Flag The Post
See more
See less
bike wont start
  • bike wont start
    Just as the title says, bike wont start. When you hit the starter button, the compression release solenoid clicks but no starter, nothing. I was at work and trying to get home so i cleaned/checked terminals and all was ok. I even tried to jump it off, battery is still hot. I pulled the tank and yanked the plugs and while in gear i pushed the bike and the pistons pushed and pulled air just fine. So i guess when i get it off the trailer i will try to run a hot wire to positive lug on starter just to see if it will hit. Is the starter relay like typical relays, infinity across 2 terminals and continuity after 12 volts are applied, thanks.
    Check the brushes in your starter, mine was intermittently not cranking and I found the brushes broken at the 90 degree bends. If you do require a starter relay I have never heard of anyone getting the cheap knock off to work reliably, I would stick with the Yamaha relay or wire in the automotive ford relay as per davej.
      So i guess when i get it off the trailer i will try to run a hot wire to positive lug on starter just to see if it will hit...
      Might have diagnosed it on your own. Just jump the two terminals on the relay. If nothing, pull the starter and have a look-see inside.
        My Bike did the same thing, ended up being the Starter Relay/Solenoid was shot................
        I March on the Road of Bones
          Check relay first...I assumed you cleaned the contacts in the right side switch housing ? I recently had to sand/clean mine and I just cleaned and rebuilt starter.
            The starter relay was bad. I hot wired it and the switch did not close, so there ya go. I took posters advise and purchased a factory relay, though i was tempted to buy 6 of the china made ones for the price of just one oem. Just waiting to get off work early enough to put it on, thanks fer the help guys.
              Well that was an easy one. Glad it was.
                I got the relay installed today and she fired right up, thank the Lord Jesus, now i just gotta get enough time off work to enjoy it, thanks for all the help.
                Last Post Kroyleahcim
                621 responses
                Started by Bikerron, 17 hours ago
                Started by Kevin Di, 17 hours ago
                Last Post Kevin Di
                Started by Jclevesque, 3 days ago
                Started by Jed Milhorne, 4 days ago
                Started by BubbaKahuna, 01-26-2019, 01:56 PM
                90 responses
                Last Post AreikUSA
                Started by Overkill jones, 3 days ago
                Started by J89k, 23 hours ago
                99 responses
                Started by Deerkiller, 2 days ago
                Started by Brian Schenk, 06-20-2019, 09:08 AM
                Last Post Jed Milhorne
                Started by zulater1990, 2 days ago
                Last Post zulater1990
                Started by Messer2.0, 05-02-2019, 02:34 PM
                Last Post Deerkiller
                Started by midnitmike, 4 days ago
                Started by Claymeister, 03-30-2018, 10:20 PM
                94 responses
                Last Post Overkill jones
                Started by rick2511, 2 weeks ago
                Last Post rick2511
