Gear Oil
  • Gear Oil
    I am thinking I should change my gear oil. I used Royal Purple in the past (no complaints) SAE 75W-90 Synthetic. I still have quite a bit left (1/2 quart) I think I changed it last about 5 years ago (may be longer, eeks). Can I use what I have left or should I buy a new bottle? I see no expiration date.
    Also, where are the instructions for changing it? I don't remember.
    WDYT?
    Shouldn't be a problem. Just drain the xfer case from underneath. [be sure not to drain the engine oil by mistake} Then remove large slotted plug on the side of the case, being careful not to damage it; it's chromed aluminum and gouges *really* easily. Then remove the small allen screw next to it and fill until the gear oil starts seeping out of the little allen screw hole.
      Download the owners manual. It explains how it’s done. All year models are done the same way.
      https://www.manualslib.com/manual/66...tar-Xv16a.html
        On the fill cap. I took a large washer and grinded down one side, flat for about an inch. Then wrapped it with electrical tape. Use a adjustable wrench with it. Work well for the large fill cap! No damage!
          Do you know how thick the washer you used was? Thanks.
        I wouldn't worry too much about the 5 year interval. I've had my bike 6 years and have never changed or even checked the gear oil.
          Mort, It was a 1 1/4" washer maybe 1/16 thick. I used the electracal tape to protect the cap and to thicken the washer. 1 1/2" washer would be better.
            Thanks.
          Google " changing gear oil in a road star". It is a YouTube by James Adam. BTW, I would not use the gear oil you have left if it's 5 years old. Just saying.
          • highvoltage
            highvoltage commented
            Thanks for clearing that out for me. I was always under the impression when the container was opened deterioration of the oil began. Learn something new everyday.
            You have that confused with a beer.
          • highvoltage
            LOL. That must be why I drink all the beer and leave nothing in the container.
          Maybe I missed it, did he cover if the bike is level or on the kickstand..?
          • Cheapa$$jimmy
            Cheapa$$jimmy commented
            Bike is level. I put the kickstand on a 4x4.
Name:	Screen Shot 2019-03-13 at 9.46.00 PM.png
            My pipes cover the oil level hole, I just drain the old fluid and put back in a little less than a 1/2 qt. Anymore than that and it will find a way out!
            Started by Father Pobasturd, 8 hours ago
            Started by 03LiquidSilver, 3 hours ago
            Last Post 03LiquidSilver
            Started by Beaker13, 8 hours ago
            228 responses
            Started by zingpow, 12 hours ago
            Started by YZ18, 6 hours ago
            Last Post YZ18
            by YZ18
            Started by viking, 11 hours ago
            Started by jamez1965, 7 hours ago
            Started by darkstar, 6 days ago
            Started by Doc_V, 6 days ago
            Started by Laidback, 10 hours ago
            Started by Cthom32, 1 day ago
            Started by tyates007, 1 day ago
            Last Post Jeaston
            by Jeaston
            Started by zingpow, 03-20-2019, 11:59 AM
            65 responses
            Started by Father Pobasturd, 13 hours ago
            Started by Doc_V, 1 day ago
