different fuel tanks on the R*
  • different fuel tanks on the R*
    hi all
    just wondering if anyone has ever put a smaller tank on their roadie custom build? i've seen some good stuff on here over time, most people have opted for a sportster or king sportster tank, is there anything else that will go on with minimal F## ing about? i know id have to part with stock speedo but that's no biggie, its the tunnel width perhaps that is the killer
    anyway sing out if you know of anything..
    Sporty tanks have mounting tabs on the front, so you would have to cut off the Yamaha mounts in front. On the back if you wanted to keep the bolt arrangement just make a new mount, the new sportsters with efi have so much wiring it's on the bottom of the frame tube also. My tank is off right now I can measure how wide the frame tube is.
      Check out the tank on Lucky's Black Diamond Build. I believe it's a Mustang. So many have done the Sportster tank. Be original.
        When I do mine I'm going to try a Yamaha 70's 500 or 650 tank.
          Not sure if this helps or not
            thanks all, including the pics on tank sizes much appreciated! as it turns out i have an xs 650 tank, it will take a bit of straightening up anyway before it goes on, but nothing ventured etc! ill check lucky's tank set up FPB
            Started by Father Pobasturd, 6 hours ago
            Started by Redbeard, 3 hours ago
            Last Post Redbeard
            Started by Dieseltechreno1, 1 day ago
            Started by YZ18, 2 days ago
            Started by Kevstephenson7, 13 hours ago
            Last Post FireFighterZero
            Started by drumsonly2002, 13 hours ago
            Started by darkstar, 1 week ago
            Last Post Penguin
            by Penguin
            Started by cike, 12-29-2018, 05:07 PM
            Started by JoeBloShmo, 2 weeks ago
            Started by Doc_V, 01-17-2019, 08:26 PM
            72 responses
            Last Post 03LiquidSilver
            Started by jamez1965, 2 days ago
            Started by Doc_V, 1 day ago
            Last Post Deerkiller
            Last Post Kenkaman
            Started by Dannyboydaniceguy, 22 hours ago
            Last Post Dannyboydaniceguy
            Started by Laidback, 2 days ago
