Added a gauge
    old thread, but look what the manual specs re oil pressure are , is this correct?
    0.057-0.114 psi at 900 rpm on the oil tank?
    never mind, found it in another thread
      The port I used was a main port that feeds the left crank bearing, #1 connecting rod bearing, left starter/generator shaft journal, and the heads rocker arms. The port is just below the banjo fitting for the heads, and is machined for a m8 banjo fitting. I used a old head manifold line and cut the banjo fitting line where it starts to go 90 degrees at the tee. The line is 1/4", and I bought a premium stainless compression fitting to use on the oil gauge line. Using a piece of 1" aluminum strap as a support bracket, and studded the right bolt hole on the starter shaft journal cover. The 1.5", 0 to 100psi gauge is very rigid with the engine and is a Marshall liquid filled type.
      Started by Jaybo, 9 hours ago
      Last Post Sparky928
      Started by Smoke, 08-02-2018, 10:02 AM
      Started by Blackbeard, 19 hours ago
      Last Post Blackbeard
      Started by Dave A, 1 day ago
      64 responses
      Started by Hairless Hippy, 5 days ago
      Started by Sparky928, 6 days ago
      Started by Madmac, 4 days ago
      Started by MikeyC, 4 days ago
      Started by Pauli466, 6 days ago
      Started by rondo_calrissian, 1 week ago
      Started by Sharpman66, 6 days ago
