14" apes questions
  • 14" apes questions
    I know this has all been covered before in the old forum, but now that I can't search that info..well
    I am looking at either 12 or 14" apes. I have had 12" on a past bike and know what they entails. With 14" will I need to extend the wires?
    i'm thinking DNA monster apes. Anyone have any experience with them?
    I have 12" on mine and made the wires work, I'd bet you could get 14's to work, but you would have to do the brake line.
      thanks. I already have the longer upper brake line.. how tall are you if you don't mind me asking? would you consider going going 2" taller to 14"? It has been a couple years since I had 12" bars on a road star and can't really remember how they felt height wise
        Go for a ride and put your hands on the top of the mirrors (if you have a throttle holder) to give you an idea. but yes, I want to go to 14" and I will likely just do it with Risers. I'm 6'1" but I have short legs (30" inseam) so I do have a tall body. I rode my buddy's HD with 16" apes and they were actually not too bad.
          pulled the trigger on the 14" bars. should be here in about a week
            I have 15's and the wires worked fine routed behind the top tree. Longer cables and upper brake line.
            Life is short, eat dessert first----Unknown
              A lot will depend on the actual shape and width of the bars. Taller bars with a narrow width and profile may work without messing with extending the wires but a shorter wide width bar may not.
                here is what I got.
                Rise: 14" rise
                Width: 35"
                Pull Back: 6"
                Center Width for risers: standard 3-1/2" from center to center of knurls
                Center Width total 1" portion: 5-1/2"
                Tube Diameter: 1.50"
                Width (at bottom, outside): 13-1/2"
                Width (at bottom, inside width between risers): 10-1/2
                guess i'll know soon enough if the wires will work.
                My current bars are 34.5 wide and I like that width pretty well so I didn't want to go much wider.
                As for the pull back and such, it's a shot in the dark as I don't really know what I want there. I did need at least 10" width in the lower inside for when I have the faring on and these are 10.5 so that part is great.
                I hope the bars look as good in person as they do in the pick. $199 is by far a lot more than I have ever paid for a set a handlebars..but I really wanted these so I bit the bullet and paid the extra money. now I'll just cross my fingers and hope I didn't blow $200.... good thing it is only money
                • TimB
                  TimB commented
                  You may need to enlarge the outside edges of the risers for the 1.5" bars
                My 15's are also 35" wide but I don't have any pull back. Like stated above, that could be an issue. I was expecting to do my wires and was surprised they made it. Those are sharp looking bars, going to look sweet.
                  If you do extend your wire through the bars , what should be done about those holes where the wires went into the control housings ?
                    You should be able to find plastic or metal push in plugs at the hardware store to fill the hole. I know they sell black plastic ones in the pullout drawers at HD,Lowes and ACE hardware. here are some examples.
                    https://www.google.com/search?q=plas...PfhnA-f_KqXXM:
                  • Horsehammerr
                    Horsehammerr commented
                    Thanks davej , with that many choices, something ought to fit . Probably a dab of silicon seal to waterproof will work.
                  • Horsehammerr
                    Next Question : anyone got pictures of routeing wires into handlebar openings under controls , so they don't get crimped ?
                  Im running 14” krome workz Ape hangers. I extended the wires 18” to run on the inside of the bars. Im 5’9” 32in inseam and a Corbin seat and they fill great. With my old Saddleman Seat they felt just a bit tall.
                    16 in whole setup in RSC facebook page , stock bars are 8 in tall plus riser? the oem yamaha 4 in riser works well for small pullback and lift no recabling req
                      Is there a certain correct way to route the wires into the Bar ends to avoid crimping ans breaking a wire ? This will be the first time I've done this , HELP .
                      Make sure to stagger the splices so there isn't a big wad in one area. I soldered then heat shrunk the the splices. Try to get it so a spice isn't on a bend. I've done this 3 times with no issues. Make sure the wires are spliced to the right ones.
                        I went to harbor freight and got those white boxes of heat shrink and wrap the whole set a wire before push pull use weed eater line to fish overlap tape use monkey snot and other lubes to get itg thuu chamfer sharp spots with file first
                        Started by Ahodge75, 11 hours ago
                        Started by twowheeltherapy, 6 days ago
                        Last Post ChuggerRider
                        Started by jdhard0341, 1 day ago
                        Started by J89k, 2 weeks ago
                        Started by RoadieRob, 2 days ago
                        76 responses
                        Last Post Jackdogz
                        Started by cap-tech, 1 week ago
                        Started by Darkkill57, 3 days ago
                        Started by Bear1433, 2 days ago
                        Last Post Bear1433
                        Started by Cubo55, 3 days ago
                        47 responses
                        Last Post Blackcloud12
                        Started by NCB, 5 days ago
