I made a boo boo need help
  • I made a boo boo need help
    I lifted my tank and sort of leaned it over to the left against a chair but still connected so i could plug this dobeck tuner into the fuel injector harness. After reconnecting the vent line, and the small green connector that comes out from under tank near battery, everything should be good i thought. I fired the bike up and my tank with gas in it reads empty, i have a check engine light, and when i rev it, it stalls out soon after. So i unplugged the tuner and plugged the harness back together, fired it up and same thing so its not an incompatibility with the tuner. Somehow i damaged a connection that tells it it has fuel or somehow unplugged something. any tips?
    It makes a click noise briefly after shutting it off
      Vapor lock?
        Just guessing but, Recheck all your connections and then let it sit for 10 min with the tank reinstalled. The sending units for fuel level do not read quickly or your gauge would fluctuate over every bump or hill. Possibly on an injected model the pump may shut down to prevent overheating if it thinks there is no fuel to cool it. Like I said, I’m guessing.
          Ah got it, i had bent a pin in the connector. Check engine light is gone and the bike runs normal now. Hopefully like ya mentioned, the gas gauge will kick back in after riding it. Thanks!
            Be sure to get back with us with an honest review after you get through fiddling with that thing.
            • Deerkiller
              Deerkiller commented
              Indeed
              The fuel controller specifically.
          Started by Darkkill57, 7 minutes ago
          1 view
          Last Post Darkkill57
          Started by GreasySam, 08-22-2018, 10:45 PM
          Started by Father Pobasturd, 3 hours ago
          Started by tdor54, 03-17-2019, 08:04 PM
          Started by Dick M, 3 days ago
          320 responses
          Started by Jclevesque, 11 hours ago
          Started by Whitty, 1 day ago
          Started by drumsonly2002, 1 day ago
          Last Post blueverclear
          Started by RedManR1, 3 days ago
          Started by BubbaKahuna, 6 days ago
          Last Post beau1
          by beau1
          Started by Cdub, 2 weeks ago
          Last Post Cdub
          by Cdub
