acceleration
  • acceleration
    Anyone know what their Wild/Road Star standing start to 60mph time is , info in relation to standard motor or tuned
    The 1700 (2004 and newer) 1/4 mile time was 13.9 sec. @ 93.12 mph
    Peace,
    (But you can call me Joe)
      thanks , but was asking 0 to 60mph times
        0 - 60 in an afternoon!
          Mine’s like 0-60 in one minute.
            Peace,
              Vmax best 0 to 60 from Yamamom.
              The #1 resource for Star Motorcycle 0-60 & quarter mile times offering a comprehensive index of Star bike specs including Star Stryker C, Bolt R-Spec, Raider SCL & more!
                Cruzer
                  Roadstars can get all the way up to 60mph?
                    I know I've had mine there... but, I so take my sweet time anymore... I don't actually know how long it takes. Can 60 be hit in first before the rev-limiter cuts in... when using one of them Dyna 3000 things set at 5,000 RPMs? I've never tried... I can't help it, but it may sound like short-shifting, but since installing Dynas in my R*, I haven't hit the rev-limiter even once since. I must be a wussy!!!
                      I don’t believe I’ve even bumped mine @ 4,250.
                      This high revving society doesn’t seem to understand long stokes.
                    • Questcap
                      Questcap commented
                      I hit mine once at 4,250, while trying to pass a truck quickly... the extra little bit of time it took to grab the next gear convinced in that instant... to get the Dyna, and never get caught having to throw a quick shift again, when I needed to keep accelerating!
                    No. You can in 2nd tho. You'll hit limit around 35 or 40 in first. 2nd should take you at least to 70.
                      Thanks, I was only curious... I'd probably never actually try, unless I some reason HAD to. I'm an easy rider. At my age, I've nothing left to show or prove, and don't engage in 'high-risk' activities anymore. I prefer to watch others make the fool of themselves... that I used to be!
                        Fact is, I found out where limit was in 1st, 2nd & 3rd on a Dyno. 3rd, BTW hits limit somewhere at or above 100mph.
                      With a 4750 rpm limiter, I can get 38 in first, 62 in second, 89 in third, and 109 in 4th.
                        Don't know of the top off my head. I do know it's not as fast as sport bikes but it is as fast as, if not faster than most sports cars for the first couple hundred feet, after that the higher end cars would walk away from a R*. That said, I just installed an app to test this; I'll post my results after I try it out.
                        If I had to guess, I'd put it in the 4-5 second range. [give or take] It will be interesting to see.
                          More like 5. I swap back and forth between my SV and my Road Star. Not even close, and the SV is not a “high performance” machine.
                            With a 14.0 quarter probably mid to high 6 sec 0-60 with a perfect 1-2 shift....in other words you would get beat by LOTS of cars out there now a days. He'll V6 Camaro and Mustangs run low/mid 13's and some pickups/SUV'S would hang right with the R until 115 mph...at which point they would pull away.
                              At 115 we don't have much left anyway.
                            I can't speak to the accuracy of the app I used but I was consistently getting 4.3 second zero to 60 times. [Best was a 4.2] I'm sure someone without all the gear I have, and who weighs 50 lbs less than me, could get a better time.
                            • sta-lor
                              sta-lor commented
                              thanks , only one that answered the question
                            https://www.zeroto60times.com/vehicl...-60-mph-times/
                            • TimB
                              TimB commented
                              That chart looks reasonable
                            • Deerkiller
                              Deerkiller commented
                              Love the V-Max 0-60 times
                          Started by Rob in FL, 9 hours ago
                          Last Post Fat pete
                          Started by 6175biker, 1 day ago
                          Last Post 6175biker
                          499 responses
                          Started by Emra, 2 days ago
                          Last Post Emra
                          by Emra
                          Started by KCpartsguy, 1 week ago
                          Started by Texas Jim, 2 days ago
                          Started by Anthony385, 18 hours ago
                          Started by Zimasfriend, 3 days ago
                          68 responses
                          Last Post fastjohnny
                          Started by Shores, 3 days ago
                          Started by midnitmike, 2 days ago
                          Last Post LeLimoMan
                          Started by cike, 2 days ago
                          Last Post LeLimoMan
                          Started by Roadman68, 3 days ago
                          Last Post LeLimoMan
                          Started by Scjpll, 1 day ago
                          Started by ItBeMe, 1 day ago
                          Started by boomerA, 1 day ago
                          Started by Jclevesque, 1 day ago
                          Started by Smar84, 04-30-2019, 08:44 AM
