2005 Yamaha roadstar gas cap
  • 2005 Yamaha roadstar gas cap
    Anyone have issues with their gas cap not venting properly? I believe that is the problem I’m having with my bike.
    The caps are to intended to vent. If you are still running with a fuel pump, you shouldn't have to worry about it. If you've gone pumpless, the tank needs to be vented in some manner. The cap can be made to and there used to be a tech article with instructions on doing so.
    Peace,
    (But you can call me Joe)
      Ok I still have a fuel pump, how do I know if it’s going bad ? Should it constantly be pulling gas from the tank ?
      • Txulrich
        Txulrich commented
        The fuel pump will only run when the it thinks gas is required (when the pressure in the fuel line is low enough). When you first turn the ignition key, you should hear the fuel pump clicking as it fills the fuel line. It should stop as the float bowl fills up.
      If you think it's not venting, check your rollover valve. It's like a double acting check valve, and is supposed to vent thru that valve. I have found them to stick or get gummed up. Most of us remove that valve and just run it straight thru. The valve location is behind the side covers and mounted on the down tube part of the frame.
        Found out why my gas tank wasn’t venting right, the vent hose coming from the tank was kinked. Fixed it right and now the fuel is flowing properly to my fuel filter and fuel pump. Bike is running fine now. Thanks everyone for your help.
          This’ll never do.
          only 8 hours, and the threads done.
          3,304 responses
          Last Post Jaskin71
          Started by Doc_V, 3 days ago
          Last Post Rodzim
          by Rodzim
          1,023 responses
          Started by tyates007, 3 hours ago
          Last Post Moser39
          by Moser39
          488 responses
          Started by D-Fresh, 8 hours ago
          Started by Horsehammerr, 4 days ago
          Started by eardog2, 1 week ago
          Last Post Grnhornet
          Started by grubsie, 2 days ago
          Started by Mitch82, 1 day ago
          Last Post TimB
          by TimB
          Started by gary1717, 07-12-2018, 05:40 PM
          Started by LDofDC, 04-15-2018, 07:21 PM
          54 responses
          Last Post bigguyokie
          Started by Spydr, 2 weeks ago
          Started by Jaskin71, 1 week ago
          Started by Herrindude, 2 weeks ago
