PMS closing all the way doesnt do anything
  • #41
    Pondering whether 172.5 4th clip is too rich for KN univ filter and stage 1 -should get 40 mpg and need choke to start
    • #42
      Well hell, this is a mystery. How about try putting the stock PMS back in to eliminate possiblites? A 172.5 and clip on 4th groove should be fine. Besides, the main jet and needle clip don't really effect the motor at idle. What about your enricher knob? Some have recommended trimming the backside of the knob to allow it to fully seat. Try taking it off the mount under the fuel pump, loosen the rubbers side too and push it all the way in to see if that makes a difference. I don't know about 40mpg, some achieve that, I got it on my 1600 but I average 34 and 37mpg on my 1700.
      • #43
        Yeah but how many of you guys actually only have stage one which is 6 half-inch hole drilled in exhaust and cone removed ? The main jet does deliver some fuel at idle or just off idle you can see it slipping up around it you getting sucked into the engine
        • #44
          If you're still running stock pipes, [my apologies, I missed that part] even drilled out, then you probably shouldn't be jetting for aftermarket pipes. This thread had been going on so long I can't even remember if this is a 1600 or 1700 we're talking about. If it's 1600, go with the 35 pilot and 167.5 main, if it's the 1700 the 37.5 pilot and 170 main. Start with clip on forth groove, if you still don't get a response from dialing in the PMS, then move to 3rd groove.
          • #45
            stock pipes stage 1 exhaust, all 3 of my RS's, , KN universals, 1700's, all same jet kit, same knurled PMS needle so u can adjust on the fly. one my brother bought from me, but im his mechanic. when i set them all up the same, they still have minor running differences. without dino, we just do the best we can. i may try the 170 main next . optimally bike should be hard to start without choke, and feul efficient, you can tell if it is too lean, when it backfires out pipes on decell, or idle does NOT snap back down in a timely fashion and runs hot. i really like the stage 1 exhaust, its free, and has good OEM heat shields and crossover. just enuf rumble. a rich bike still runs well, buts gets poor mileage. there is a relatively wide range of Air fuel ratio that wil work. i guess the FI bikes should be a good indication of actual attainable fuel mileage we should expect on a properly adjusted carb model.
            2 points of note: a joke
            carbed RS 's are faster than FI.
            especially the black ones.
            • #46
              Well sounds like you're all over it. Sorry I can't be of more help. Keep us posted. BTW, black and *red* bikes are faster still.
              • #47
                FINALLY got the bottom of this on this bike, although the choke was pushed in all the way, the plunger was pulled up slightly on the carb end. BAD CABLE, scabbed one off spare carb. good to go now tho, may have to put back 37.5 idle/pms jet
                Started by Parhamj, 5 hours ago
                Last Post 07 silverado
                Started by Pauli466, 1 hour ago
                Started by bencadenbach, 5 hours ago
                Last Post bencadenbach
                Started by Parhamj, 1 day ago
                Last Post Parhamj
                by Parhamj
                Started by brianmac, 10 hours ago
                Started by GNR10, 2 days ago
                Started by jjvw, 1 week ago
                Started by roadiemort, 15 hours ago
                Started by ItBeMe, 1 week ago
                Last Post texasscott1
                Started by Ret HPD, 1 day ago
                Started by gold03, 1 week ago
                Last Post gold03
                by gold03
                Started by Lucky, 5 days ago
                Last Post Spydr
                by Spydr
                Started by cap-tech, 3 weeks ago
                Last Post Vicious
                by Vicious
                Started by GNR10, 1 week ago
