I have an 04 with about 26,000 miles on it. I think that the steering head bearings are loose or in need of replacing. ( flop test fail on both sides) Is this something that can be done by a novice or should I let a pro. do it? Local shop said it would be $360.00, does that sound about right for what has to be done? And will it hurt to ride it the rest of the season and wait till winter to get it fixed. I think that is where the excess vibration is coming from.
The local shop has done some work for me before, they are ok, if it were a car motor, no problem, just don't trust myself to do the job right the first and only time I have ever done it. Going down the road at 70 mph. is not the time to second guess your work.
I did mine a couple of years ago together with the forks. It was a hell of a job, very satisfying though. The only thing I would do differently is buy a few extra tools to remove the bearings. Like SKWEARpeg said, how mechanically inclined are you?
The bearings are not well lubed from the factory. To do it right, you should repack them. Or, you can easily loosen the two pinch bolts on both sides of the top triple tree, tighten the two head nuts with a hammer and screw driver, tighten the center tree nut then retighten the pinch bolts. Better than ignoring it all together.
You never know what might not work right, or get messed up at the dealer. I personally don't want anyone working on my bike but me. But, I have been a mechanic all my life, so naturally I am going to work on my bike. But if you don't feel comfortable doing it, then you don't have much of a choice. Its not that hard to do, but you have to do what is best for your situation. You can study up on what is involved in doing the job, there are videos you can watch and see what is involved. But its your bike and decision. Good luck which ever route you decide to go.Where ever you go, there you are.
- Likes 1
Originally posted by cat daddy View Postif it were a car motor, no problem, just don't trust myself to do the job right the first and only time I have ever done it. .
Originally posted by Shores View PostThe bearings are not well lubed from the factory. To do it right, you should repack them. Or, you can easily loosen the two pinch bolts on both sides of the top triple tree, tighten the two head nuts with a hammer and screw driver, tighten the center tree nut then retighten the pinch bolts. Better than ignoring it all together.
Here's how I did it. Whole job takes about 30 minutes and 2 beers.
Put bike up on jack so front wheel is off the ground.
Remove front wheel (requires removing the brake calipers, 2 bolts on each) I wrap them in rags so as not to scratch the front fender.
Cover your gas tank with several rags or a thick blanket material
Loosen the 4 bolts clamping the upper triple tree to the fork tubes
Remove the center nut on top of the triple tree.
Lift the triple tree with the handlebars and cables in tack and place them gently on the "covered" tank or you could string the handlebars up in the air like I do by attaching rope to the joists in my barn.
Loosen the double lock nuts on the triple tree up to the end of the threads but not remove. This will allow the lower part of tree to hang low enough for easy access.
Squirt a bunch of marine grade grease in the lower part of the tree so the lower bearings are damn near swimming in the stuff.
Slide the lower tree back up into place and squirt a bunch of grease in the upper bearing.
Tighten the double nut good and snug with a decent amount of force. Then loosen it a little then re-tighten it as best you can by hand
Clean as much of the excess grease you can from the top and bottom of the steering neck.
Put the top tree back on and just snug the center nut by hand.
Then do the flop test and use a punch or screwdriver to tighten the double lock nut under the upper tree until the results of the flop test are just where you want them.
Once there, tighten the center nut and the clamp bolts for the tubes, put the wheel back on, then the front calipers.
Ride like you stole it!
Eezy Peezy!
- Likes 2
I do this procedure without removing the front wheel. As long as you can get the bike high enough off of the ground, you can use blocks under the wheel to hold it up while greasing bearings. I do my final flop test with the front end totally assembled as ridden, the weight on front end has an affect on how the forks fall.
So if I'm reading this right. If I just want to tighten the bearing I can loosen the pinch bolts center cover bolt and tighten the nut with a hammer and flat screw driver? I assume that you would try to tighten the lower bolt and the top bolt will come with it, correct? Look like both the lower and upper nuts are together with a set tab? I don't have any movement in the wheel, just will fail the flop test. I think due to the fairing with speakers and amp in it.
If it hasn't been lubed in a while, I would do so before tightening it. With the top off, it's not that much more work to drop the steering and load it with grease. I do mine every year.Peace,
(But you can call me Joe)
Originally posted by Txulrich View PostIf it hasn't been lubed in a while, I would do so before tightening it. With the top off, it's not that much more work to drop the steering and load it with grease. I do mine every year.
Originally posted by Horsehammerr View PostEvery 2 years works for me. I know it needs looked at when I get a Slight Wobble in a higher speed curve. That's the for sure Flop Test that works for me.Peace,
Originally posted by NCB View PostSo if I'm reading this right. If I just want to tighten the bearing I can loosen the pinch bolts center cover bolt and tighten the nut with a hammer and flat screw driver? I assume that you would try to tighten the lower bolt and the top bolt will come with it, correct? Look like both the lower and upper nuts are together with a set tab? I don't have any movement in the wheel, just will fail the flop test. I think due to the fairing with speakers and amp in it.
The two nuts are separate.
After loosening the pinch bolts and removing the crown nut, you can lift the upper bridge(if the windshield brackets have been removed).
You need the upper bridge far enough out of the way to lift the funky two legged lock washer.
Now you tighten the torque with the bottom tension nut. Then, run the top nut down to finger tight, only tightening a bit more as needed to drop the funky two legged lock washer back on.
When its all together, with weight off the front wheel and the bars centered, a slight nudge should start the wheel falling one way or the other. The wheel should move smoothly to the stops, and not bounce.
When you’re in there, you’ll see how you need to have room enough to lower the front wheel far enough with the top assembly removed from the top end of the Stem, to expose and repack the lower stem bearing.
Txulrich - You need to remove the speedometer assembly to lift this off. It also makes more room to get at the crown nut.
Txulrich - I would remove both nuts and examine the top bearing. If it's worn or dry, you will know if you need to look at the bottom one.
When you’re in there, you’ll see how you need to have room enough to lower the front wheel far enough with the top assembly removed from the top end of the Stem, to expose and repack the lower stem bearing.Peace,
Originally posted by cat daddy View PostDoes not sound that bad just to grease the bearings, but what if the bearings need to be replaced? All of it would have to come apart. How easy is it to remove them? And do the races need to be replaced also?
Yes, you will be replacing the races as well.
You drive the races out of the neck from above and below.
The lower bearing can be a bit of a stinker to get off the Stem. Some press the Stem down thru the lower bridge thus removing the lower bearing. Others have managed to work the bearing up using a cold chisel to leverage the bearing up off of the lower bridge.
AllBalls makes a good bearing replacement set. It’s the same for all years, and comes with seals.
New Member
by dwilli
Started by dwilli, 4 hours ago
1 hour ago
Started by BloodMoney, 1 day ago
3 hours ago
Started by Aflion, 1 day ago
by Littlebull
8 hours ago
9 hours ago
Started by ItBeMe, 1 day ago
by Littlebull
9 hours ago
Started by 07Roadstar, 02-28-2018, 02:46 PM
by chess
17 hours ago
46 responses
18 hours ago
Started by 07Midnight1700, 1 day ago
22 hours ago
Started by Blackbeard, 01-06-2019, 09:48 AM
Started by 07Midnight1700, 2 days ago
Started by Ronin325i, 1 week ago
by Ronin325i
Started by Matty1, 4 days ago
Started by Lug Nut, 4 weeks ago
Started by Debevec, 3 days ago
by Mr. Miyagi
Started by Tomtom123, 4 days ago
by Mr. Miyagi
Started by Mc765, 3 days ago
by Gwhiz
Started by Jammin'John, 4 days ago
Started by 08BlueRoadStar, 3 days ago
by Debevec
