REjet or adjust the PMS screw tighter than 2 1/2 turns?
  • REjet or adjust the PMS screw tighter than 2 1/2 turns?
    I currently have my '07 RoadStar jetted with a 175 main jet, 40 pilot jet, and PMS at 2 1/2 turns. The exhaust pipes and plugs seem to indicate that the bike is too rich. MPG is 30-33. Should I go to smaller MJ or PJ or turn the PMS to closer to just 2 turns for better milage and still retain enough power for highway riding ?
    do you have a Barons needle? If so go to a 172.5 main jet set the needle clip in the 4th groove and 1 silver washer under the clip. If a Dyno jet kit still use a 172.5 main jet but may get away with needle clip in 4the groove and no washer under clip. If you feel it is still a little rich go to the 3rd groove with a washer under the clip. You may have to also play with the pms, turning it in to 2 - 2 1/4 as long as it don't effect idle or stumble just off idle. Regardless of anything else the 175 is to big.
    Edit see my post below for correction
      My needle ( which it took seven years for anyone on this forum to recognize) is a Speedstar, now in the fifth groove. It had been in the fourth, but that caused a almost fatal stumble off idle. By 'fatal stumble' I mean that, while starting out from a stop, like a traffic signal, the bike almost would die , unless I gunned it and slipped the clutch.
        Did I miss something? What air cleaner are you running?
          his profile just says BAK
        I checked your profile again and realized you are using a Speedsar needle BAK and just slipon mufflers and not a complete aftermarket exhaust. With that I will change my statement above. With a Speedstar needle you should be real close on the jettingwith the 175/40 and 5th groove. Maybe remove the silver washer that is under the clip, that will lower the needle by 1/2 groove distance. Or even go to the 4th groove with the washer under the clip. I'm thinking the slipon exhaust is still restrictive in comparison to a complete aftermarket exhaust. .Also make sure the air filter is cleaned
          I have Cobra Dragster pipes on the bike. It came that way.
          Started by 08BlueRoadStar, 22 hours ago
          Started by MikeyC, 18 hours ago
          1,450 responses
          Last Post chess
          by chess
          Started by [email protected], 6 days ago
          112 responses
          Last Post Ypsilonn
          Started by Judd, 2 days ago
          Last Post Judd
          by Judd
          Started by Shores, 4 days ago
          124 responses
