Are they still available and who is has them? Going to by a fairing for the bike and this is the one I want! Thank you Brett
Road glide mount
Originally posted by Engineman View PostAre they still available and who is has them? Going to by a fairing for the bike and this is the one I want! Thank you Brett3 Photos
I know some guys had some difficulty installing a setup from a guy from the old rsc. How different is Ryans? I am a big fan of the RG fairing.
Originally posted by Chico View Post
Dude,ur gonna love it! I had a street glide fairing on my bike,but always wanted a roadglide fairing so finally I got a hold of Ryan Kirkpatrick and bought one of his mounts and a roadglide fairing and off I went! It's still in progress
Parts you'll need for install:
1. Inner and outer fairing. This can usually be found on eBay as a set for $2-300
2. Radio caddy. This will attach to the inside of the inner fairing and bolt onto my bracket. This will allow you to mount a radio and also serve as a base plate for mounting additional accessories like and amp, fuse block, etc.
3. Headlight assembly and bezel. Pretty self explanatory.
4. A secondary mount of your choice. My bracket sets the distance and angle for correct clearance with the forks and tank. But the fairing is made of plastic and will still flex on the edges. You'll want to stabilize it to keep it from flexing and eventually cracking. My recommendation is either use the crash bar/turn signal mounts the like the lower rear corners to the crash bar, or use ghost brackets the link it back to the neck of the bike. Chico Malo made his own ghost brackets pretty easily, he might be able to turn out a set for you too. I DO NOT recommend the the Trask hidden mounts.
5. Windshield of your choice.
6. Stereo, speakers, and gauge fillers of your choice.
Keep an eye on all the HD parts pages and you can usually come across a lot of these parts for dirt cheap. You should be able to get into the whole assembly for $5-600 or maybe less, plus paint and however crazy you want to get with audio.
92 responses
2 hours ago
Started by MikeyC, 3 days ago
2 hours ago
Started by roadiemort, 7 hours ago
5 hours ago
Started by Jeffw, 1 day ago
5 hours ago
Started by BC1955, 5 days ago
by BC1955
8 hours ago
Started by Rilcoat, 4 days ago
9 hours ago
Started by Doc_V, 09-23-2020, 02:48 AM
80 responses
9 hours ago
Started by LDofDC, 12-23-2020, 12:17 PM
120 responses
16 hours ago
by Rilcoat
Started by zert800, 1 day ago
by zert800
Started by AZRoadie, 4 days ago
by EP Roadie
Started by TexFer, 12-30-2020, 10:46 AM
by TexFer
Started by Rilcoat, 2 days ago
by Rilcoat
NRA
Started by Duke, 3 days ago
