Middle drive
  • Middle drive
    I seam to have a bad bearing in my middle drive/reduction? What is it actually called?
    How hard is it to replace bearings in this unit? Bike has 103,000 miles
    Transfer case? Well that sucks! Is your other bike rideable? Is Jeanette coming on her trike?
    • MikeyC
      MikeyC commented
      Trike is in the shop, we will be riding the two up bike. This is one of my commuter bikes thats broke.
    That's a lot of miles. That's 721,000 in dog miles.
    • MikeyC
      MikeyC commented
      LOL I like the dog miles
    Plenty of Kilometers ( USA )
      A Gold Wing is in the shop! Blasphemy!
        They have timing belts that have to be changed, who woulda thunk. and a temp sensor was out and on back order
          On the early models, you had to split the cases if you fried a stator.
        The bearing behind the front pulley went bad on mine. I replaced the bearing on either end of the drive shaft, front pulley and the shaft. Nut came loose and caused havoc on the pulley and the shaft. the bearing are a bitch to get out. I tryed several kinda of pulley tools with no luck! Talked to a couple of mechanics and they said they would have to be pressed out? Well, I'm a carpenter and after looking around the shop I found a 1/2 wooden dowel about 3' long. Fiqured it could'nt hurt anything so I went to the right side put the doewe in from there and drove the left side beering out from the back. Did the same to the other side. Froze the new ones over night and they went in without a problem Been good for the last 5k!
          Hey cool! Sounds like what i need. Was it a straight forward job? No fancy tools.
            I have a wooden dowel
              Was there just those two bearings? And you don’t happen to have the part numbers do you?
                https://www.yamahasportsplaza.com/oe...dle-drive-gear
                  # 2 and # 3 I believe?
                Mort is correct.
                The only bad bearing was the one behind the pulley. I just replaced them both since I had to replace the drive shaft. The dowel and hammer was the only odd tool I used. I just kept moving the dowel around the back side of the bearing while hitting the other end of the dowel with a hammer until it came out. The wood being soft will not damage the case.
                  Cool. That looks doable. Thank you for all the info. Thats why this is such an awesome site
                    Did you notice any noise when the bearing went bad?
                      Ya. It’s been a barely audible noise for month’s that i kept looking for. Then on the way to work the other day it got pretty noticeable and on the way home pedestrians and cars i was passing would look and i was hoping to make it home without seizing something. I jacked it up and removed back of bike and covers and spun the wheel. I had thought it was a rear wheel bearing but turned out to be from the middle drive
                        Did you get the bearing replaced? What did you use to remove them?
                          I haven’t worked on it yet in the middle of a kitchen remodel
                          • Kmartcivic
                            Kmartcivic commented
                            I know that feeling! I'm in the middle of installing new countertops. Projects are never ending.
                          • MikeyC
                            MikeyC commented
                            LOL, that's it! We just poured Stone Coat countertops this past week end. But leading up to that was move a wall, new cabinets sinks a faucets, it never ends
                          I have other bikes to ride when one is down
                            ...and this is the perfect situation.
                          • D-Fresh
                            D-Fresh commented
                            That is a good way to be.
                        Started by JHouse, 5 days ago
                        Last Post dbtk44
                        by dbtk44
                        Last Post Rooster85
                        Started by Twinkles, 4 days ago
                        Last Post EasyTargetRN
                        110 responses
                        Started by NCB, 6 days ago
                        Started by Phil L, 4 days ago
                        Last Post K9blueman
                        68 responses
