Ride On Tire Sealant Test
    To chart calls for 8 oz in our front and 9 oz in our rear with 25% more if desired. I put 12 oz in both. I'm sure it will work better if the nailer screw stays in. The reason I rotated it and drilled multiple holes is too ensure that I was maybe drilling into where the gel had migrated when the tire was just sitting. I do like the way it balances as well as the way Dyna Beads balance but I will give Ride On the benefit of the doubt for puncture protection.
  • MikeyC
    Steve! You need to use the edge of your tires more! You could get twice the mileage
  • Tropicalrs
    I agree it works for nails and screws that stay. It has worked for me. I had a screw that the head was worn down from me riding on it. Didn’t notice an air leak so I didn’t look for a problem. That could be a negative.
  • Tykes_Place
    Maybe you don't have enough in the tire? I did the same thing last time I changed. Drilled 1/16" holes. I got a little bit of air then the slime started coming out, gelled up, then stopped. I must have drilled 10 holes or so. It could't keep up with a 1/4" hole.
    But the more common scenario would be a nail or something that sticks in the tire and stays there. The sealant forms around that. I think that something puncturing, then going away leaving a big hole is much less common.
  • mlharper
    I have used it for years and had great luck with it. It will balance and seal the tire if punctured.
    A few years back, Iran over a piece of bob-wire and it poked thee holes in the rear tire.
    I knew I had a problem because it was hitting the fender before it finally freed itself.
    I was about 50 miles from home and did not have any problems making it.
    The next day the tire was still holding air. Ended up replacing the tire because of the holes were to close to patch.
    I use it in my cargo trailer tires too.
    It is used in semi truck tires, they sell it in 55 gallon barrels for that application.
    Good luck.
    It's not supposed to settle in the bottom. I've always found it still in place around the tire. In fact I have even scraped it out of the old tire and put it into the new tire and it still worked fine. I just added a little more to make up for the little bit I couldn't get out of the old tire.
    Back in 1970 living in Kayenta, Az. by Monument Valley on the Navajo res, I had a Honda SL-70. I was told by the elder Navajos to use Carnation Evaporated Milk, "Petmilk", in the tires to seal any holes in the tubes. It does work, and I used it all of the time when living out there. One time I had a really big hole and it wouldn't seal, and let me tell you, it stunk so bad I didn't want to be around my bike. It did work for nail and sticker holes although.
    It is supposed to stay liquid and it will puddle in one area. As soon as you start riding within a mile it's flung and dispersed everywhere for the weight distribution as well as the ability to seal punctures. Luckily I've never had a puncture but all the tires I've used it on seem perfect in terms of balance no vibration etc
    started a topic Ride On Tire Sealant Test
    Will be mounting new tires so decided to see if my Ride On sealant actually worked. The bike and the wheels have been sitting for several days so it may have settled to the bottom. Maybe it works better if the wheel is spinning and the nail or screw is left in the tire. Disappointing test for sure. They must have put tons of the sealant in the tire on the manufacturer video.
    https://youtu.be/IlNuQPUl6bs
Started by Aussiestar, 1 day ago
Last Post SbTx_Rider
Started by ElVispo, 1 hour ago
Last Post ElVispo
by ElVispo
Started by Aussiestar, 23 hours ago
Last Post Aussiestar
Started by WobblyBoot, 8 hours ago
Last Post MidnightRide
Started by Kmartcivic, 2 weeks ago
Last Post WobblyBoot
Started by JHouse, 3 weeks ago
Started by MidnightRide, 1 day ago
Started by tekdiver609, 02-03-2019, 07:49 PM
Last Post Azuqui
by Azuqui
Started by WobblyBoot, 16 hours ago
Started by Renegade, 2 weeks ago
Started by Mr. Miyagi, 1 day ago
Last Post KFallsRider
Started by WobblyBoot, 3 days ago
Started by rsnyder1976, 2 days ago
Last Post rsnyder1976
Started by Do Something, 4 days ago
1,264 responses
Started by Leadkrm, 01-10-2019, 06:28 AM
Started by Apsn, 1 week ago
Last Post Tcontrol
Started by marcus, 2 days ago
Started by roadiemort, 04-17-2022, 01:19 PM
37 responses
Started by scotcher65, 2 days ago
