Finally getting on my 33/65 re-gear
  • Finally getting on my 33/65 re-gear
    I bought a 65T rear pulley a long time ago. It was a deal but I just didn’t get around to the rest of the parts. Then almost 2 years ago I got a 33T front pulley from Duke - and put it on the shelf.
    Well over this winter I started getting a small leak from the front shaft area. Last time that happened it was a loose nut. I don’t know if that’s the issue now but with my big ride coming up before NW Starfest I decided to finally get this done. So I ordered a new nut, washer, o-ring, and a 128T S&S belt. It’s gonna be a great ride.
    PGR
    PGT MT
    What was your front pulley? 32? 1700?
      Yep. 2005
      PGR
      PGT MT
        I definitely liked the lower RPM when I was rolling along at 80 to 90 miles per hour but oddly I didn't really notice better gas mileage at least not significant.
          What is your rear tire size? I'm looking to put a new tire on the bike that I've put the Warrior rim on, and wanting to try a car tire on it.
          The Warrior stock tire is a 200/50-17, (25.1), which the tire diameter is smaller than the 150/80-16, (25.4" dia.).
          I running the 33/65. pulleys on my 3 bikes now, and I really like the ratio for the lower RPMs.
          I do believe that you will like that pulley ratio for highway cruising.
            Did you have to just grind the brake caliper to get a 200 tire to fit? I had to do that for my 180 tire on my 18-in custom wheel on my purple bike I had. Anything else you did to make the warrior rim fit? I have a perfect straddle liner polished rear wheel rotor pulley tire but haven't done any measuring yet I would like to put on my 2008 Road Star but haven't done any measuring yet
            • RRS_07RdStar
              RRS_07RdStar commented
              I bought a set of Strat wheels when I had my RS. The front wasn't an issue, but the rear was going to be too much work. I don't remember the details or issues, but I do own a lath/mill and can do my own parts fabrication, so it must have been a pretty big deal. Thinking about it, it may have been something with the rear drive sprocket alignment was too far out, just don't remember for sure. I sold those set of wheels because of the rear wheel issue, whatever it was.
              Edit: Now I'm questioning my memory, I may have bought the Strat wheels for my Vstar 1300, so might not be a problem on RS??
            No grinding. Used the Warrior brake rotor and the stock RS brake calipers but had to fabricate a brake caliper bracket and spacer set up. The drive hub had to be machined to center the wheel, and that is a whole nother story.
              I figured it wouldn't be a direct bolt-on lol.
                It’s a 175/16 Austin’s Taxi tire. 27” diameter. When I switched to this tire my rpm’s did lower a bit. But not much.
                Also I rarely scrape the boards now.
                PGR
                PGT MT
                Started by Sykobox, 2 hours ago
                Started by KFallsRider, 4 hours ago
                Started by 6door7r, 7 hours ago
                Last Post 6door7r
                Started by roadiemort, 3 hours ago
                Started by Mad Maj, 4 hours ago
                Started by Kmartcivic, 13 hours ago
                Last Post Engineman
                Started by Mad Maj, 2 weeks ago
                Last Post Mad Maj
                by Mad Maj
                Started by brianmac, 16 hours ago
                103 responses
                Last Post Bnag0
                by Bnag0
                Started by 6door7r, 4 days ago
                Started by Tykes_Place, 3 weeks ago
                Started by p birk, 5 days ago
                57 responses
                Started by luff_tackle, 2 days ago
                Started by jb3472, 3 days ago
                Started by ABCarr, 5 days ago
                Last Post ABCarr
                by ABCarr
                Started by BloodMoney, 04-15-2022, 02:28 PM
                Last Post BloodMoney
