Just picked up Speed Star cdi...question...
    The 1600 are different in the heads, intake manifold, valve covers, rocker arm plates, push rods, cams, cylinders, pistons, and carburetor jets. The exhaust ports exit location are in the same place though.
    The engine cases, (short block), are the same and interchangeable.
    I have used 1700 cylinders on the 1600, but you need to use “stepped line up pins”. To make the cooling fins match up with the 1600 heads, the fins need to be contoured by shaving them down a little.
      Even you flycut the piston and get some clearance I doubt the heads will ever flow enough to "use" .535 lift cam?? Would be higher reving without much point wouldn't it? I think I'll try and focus on just cams and pistons and the new tubes for my parts collecting
        Yes Lug Nut, I believe that having .535” valve lift would be to much. You would be better off using larger valves and ported heads. It’s a lot of money for a little extra horses and torque.
          Yeah in not investing all that $ in my cheapie bobber....just after more hi comp/slight cam sound if I get good deals on some parts...sounds pretty good with the Vance & Hines short shots now
            In the gen 1 vmax community there is a company that make heads/intake (custom billet aluminum) that is insanely expensive...but with a 1570 cc big bore kit one of the bikes at an event I was at puts down 200hp NA to the tire (extended swing arm chain drive conversion)...but the vmax crowd is a lot more focused on performance/power than the cruiser crowd. I do like the HD bikes with 140-160 cube motors that make silly power but again....super expensive and I can only imagine how poor the reliability and longevity is on this beasts...
            BubbaKahuna
            Administrator
            Tykes_Place
            Admin
            Started by penningpd, 16 hours ago
            Started by Jeanson105, 2 hours ago
            Last Post Jeanson105
            Started by ACEMUSTANG2002, 21 hours ago
            Started by Duke, 4 weeks ago
            39 responses
            Started by roadiemort, 08-08-2019, 08:03 PM
            Last Post ABCarr
            Started by brianmac, 2 days ago
            Started by ABCarr, 4 days ago
            Started by BubbaKahuna, 08-17-2018, 03:46 PM
            Started by Jeanson105, 5 days ago
            Started by Tykes_Place, 11-17-2021, 01:09 AM
            93 responses
            Started by Purplestar, 2 days ago
            Last Post Purplestar
            Started by Jkeenan87, 3 days ago
            Started by ACEMUSTANG2002, 4 days ago
            Started by BrokenWheel, 5 days ago
            Started by Kmartcivic, 10-18-2021, 02:50 PM
            Started by Purplestar, 4 days ago
