Disaster hit this morning on my way to work…..
  • Disaster hit this morning on my way to work…..
    So riding to work today rear tire locked up and luckily able to keep the bike upright…….it was just draining oil everywhere and it would not roll forward but would roll backwards……I managed to free the rear wheel to allow it to move and got it on a trailer back home and on my lift……found a crack in the transfer case right in front of the rear wheel……pulled the cover and this is what I found……
    Lose all the gear oil????? Never seen a chain likenthat snap before did the nut come lose you think? Lucky you didn't slide into nsomething!!!
      Damn...that blows.
      Can't imagine what would made that front shaft shear at the nut. Took me a bit looking at the pics to realize that's what was caught in the chain at the back of the case.
        I think I see the problem...that nut doesn't belong there...
        Did the bolt shear or did the nut just come undone?
        • Ahodge75
          Ahodge75 commented
          Yep that’s one of them probably the main one…..transmission shaft sheered off
          Yeah if you look close you can see the threaded end sticking out of the nut.
        Now that's a first! Glad you didn't get hurt Aaron. Can someone post a photo of what it's supposed to look like in there?
        • Ahodge75
          Ahodge75 commented
          Thanks Steve…..I was impressed I kept it upright to be honest
        Some more photos………
        the nut is sheered off….the transmission shaft is sheered at the nut and now has a wobble bend when spinning. I can spin the shaft by hand nothing binding but has a bend.
        I had engine oil and gear oil draining everywhere…..transfer case is blown and needs replaced….transmission shaft is sheered and needs replaced along with whatever gears are broken….next big worry with all that pressure if the motor housing is also cracked somewhere which means another motor…….
          If you look real close, it looks like a crack was forming from the thread into the shaft.
        • Dick M
          Dick M commented
          I saw that Duke. Could that crack have occurred during heat treatment at the factory? We used to see those type of cracks at the machine tool co i used to work at and they were dam hard to see as the crack was such a fine line.That's what it looks like to me a manufacturing defect.
        Aaron, what do you think caused this? Did the tranny seize first and then destroy the transfer case or vice versa?
        • Ahodge75
          Ahodge75 commented
          I’m not sure…..
        I would do a good used motor if you can find one for $500 or so....hate to spend time and money and get it back together and find some other point of failure.....
        Or part out rest of bike and start fresh if you find a good of enough deal and dont mind time to part out (good $$$ in parts)
          The real question is what would cause that...seeing how it was full of oil? Is any weird sound vibration running issue prior to this? Never seen that exact failure on a road star before.
          • Ahodge75
            Ahodge75 commented
            No nothing out of the normal
          So Mikey and Duke brought up about the recall on the tranny. While I was digging into the bike Mikey ran my vin and it had the recall done……
          im really not sure what caused this it had Ben running great no issues no noises nothing. After taking with Duke I remember it kind of being a double jolt. Like bang and jolt then another jolt with tire locked up…..it happened so fast it was almost in noticeable…….I’m glad it happened today instead of tomorrow when e were all riding to Reno for street vibrations it could have been soooo much worse in a pack of bikes……
            Yikes, that sounds like a scary ride. Glad you're ok. Really interested to know cause...and how to avoid it.
            • Ahodge75
              Ahodge75 commented
              I wish I had that answer but I just don’t know……
            Bang jolt jolt sounds like shaft sheared at nut and the nut got caught between gear and chain and locked it all up
              What forces would shear the nut off?
                I've been thinking about what could cause the failure of the shaft end snapping off like it did. One thought is that when the recall was done, they had to remove that nut and gear to split the case. Then when they installed it back together, they might have over-torqued the nut by using a air impact driver?.?.?....How can you tell????
              That I cant figure out...but looking at pic...nut came off with end of bolt and got jammed between gear and chain....
              Maybe a bad part/metal fatigue ? Shaft spins but doesnt have any other forces on it
                Aaron....check your pm
                  This is a new one. Glad you are ok. Sounds like it be best to get another good running engine and salvage or part out what you have. Wonder what the heck happened. If all in the trans is free, tough to point at that as the source. If oil was changed and all was normal could be that the part just had a due date and you found out today. Dont ever think I ever saw this on here or the old forum. Weird that the nut is still on the threads….maybe over torqued upon assembly?
                    That is what I'm thinking, but over-torqued when the recall was done????
                    The lock for the nut looks as if it was doing its job, but looks a little flattened where the nut pushes against it. Not sure with out inspecting it in person.
                  Go to Facebook marketplace and search for these exact words -- Monroeville Al Road Star
                  2003 Roadie 1600 minus the tins, carb and wheels but looks like everything you need to fix your problem for 300 bucks
                  • Ahodge75
                    Ahodge75 commented
                    Thanks I appreciate it
                  This was on Facebook a couple of weeks ago. The nut backed off causing the problem.
                  I can't remember who posted this.
ID:	129979 Click image for larger version
                    Unfortunately that guy wants to sell everything and does not want to ship anything. Even if he would ship the condition everything is thing is in it would be very hard to ship that big frame with motor et cetera. The cost of shipping would be ridiculous. I sent Aaron a link to an eBay motor I was getting ready to buy that is $300 looks very nice. Trying to work out a shipping arrangement with the seller now
                      Bolt looks intact on that one. I'm betting/assuming these are 99-02 models that had the recall done. Like some else said maybe when reassembling everything they didn't useoctitr or torqued wrong or dinged up the threads??
                      Started by Sooner1, 6 days ago
                      Started by Ironman, 1 day ago
                      Started by Sooner1, 1 day ago
                      Started by MikeyC, 09-02-2021, 05:20 PM
                      Last Post Sasquatch
                      53 responses
                      Last Post TheDaveySprocket
                      Started by acczar, 1 week ago
                      Last Post SaxemaraBiker
                      Started by Darkkill57, 5 days ago
                      Last Post EnergyGuy
                      Started by LordOfTheBuzzards, 6 days ago
                      Last Post LordOfTheBuzzards
                      Started by AllStarRdr, 3 days ago
                      Started by Doc_V, 09-30-2018, 05:40 PM
                      Last Post HotRod
                      by HotRod
                      Started by Sharpman66, 4 days ago
                      by Boots
                      Started by jluisochoa, 09-27-2019, 01:39 PM
                      58 responses
                      Last Post Steelfab1
