Another Ape Hanger Question
  • Another Ape Hanger Question
    I’m looking at going with some new Ape Hangers. My question is, since I will be getting a fairing for the bike, I understand that I will need pull back risers but when selecting the bars do I need to also select the bagger style? I’m looking at a couple of different bars, the dominator cycle Meathook Apes which I can get in both styles bagger or normal. Also looking at some of the KST Kustom Apes…..so for those of you running a fairing along with Apes how are yours set up? Thanks everyone…..
    Depends on the fairing, All I was concerned about was making sure the lean angle of the fairing was about 30 degrees back for high speed stability, no apes though, stock bars with 4 up 1 1/2 back risers.
    • Ahodge75
      Ahodge75 commented
      Which fairing do you have? I’m looking at the Vector Batwing/USA Trailer fairing. Currently I’m running stock bars but they are on 6" risers turned around to move them forward that 1-1/2…..I like the position forward but want a taller bar and with the taller bar wouldn’t probably need the push forward….
      That bike had a Wide Open Customs Fairing, I think bagger style apes would work best for you on stock riser, more stable.
    I think some folks have used Royal Star risers which have a little bit of a kickback.
      Yes, those are short and stable and give you little pullback clearance Clarence.
    If you buy Bagger style bars you normally don't need risers. They have a offset in the bars to clear the fairing and also better wrist angle.
      Still got to clamp the bar, I guess you mean stock risers?
    • Ahodge75
      Ahodge75 commented
      So possibly use stock risers with bagger bars, but might still need pullback risers depending on the fairing then? And vice versa if I have pullback risers I might be able to use none bagger bars….
      I slotted my fairing mounting bracket to get it to sit lower on the headlight, too many variables until you actually get the fairing mounted.
      Last edited by roadiemort; 08-01-2021, 11:58 AM. Reason: Spelling, don't want Shores complaining.
    This is what u get with USA Trailer Store fairing. If you don't mind fabbing a bit you can make it look good too.
    • Ahodge75
      Ahodge75 commented
      Don’t mind doing some fab work…..I guess I will wait to get bars after I get the fairing……I was thinking going the other direction and get bars first but I think that would be a mistake……
    Another really bad looking install.
      Not laid back enough or down on the headlight.
    • Ahodge75
      Ahodge75 commented
      Now that’s custom….
    My own mess before I slotted my brackets, notice the black foam to lessen my pain.
    • Ahodge75
      Ahodge75 commented
      Thanks Mort….I appreciate the advice……and you can barley see that big piece of foam sitting there…..hardly noticeable….lol
Last Post TheDaveySprocket
Started by Boots, 1 day ago
Last Post mlrz24
by mlrz24
Last Post mlrz24
by mlrz24
Started by Andynz, 8 hours ago
Last Post CanadaboyA
82 responses
by Boots
RAP by zopy
Started by zopy, 18 hours ago
Started by rsokie, 23 hours ago
Last Post rsokie
by rsokie
54 responses
Last Post egelasi
by egelasi
Started by schzx14, 1 day ago
Last Post BloodMoney
