Halo led’s and turn signal
  • Halo led’s and turn signal
    I’ve searched and have yet to come across the answer I’m looking for. Just want to know if anyone has put the halo passing lamps with turn signal on their bike. Would like to install some on mine and take the actual drop down turn signal off. Thanks for any feed back/info.
    I had ask this same question on another forum and there wasn't any response that had exactly what I was looking for. But here is something close.
    https://www.amazon.com/dp/B085Z754QM...FJSG53GJEGRA99
    • Ahodge75
      Ahodge75 commented
      Posted what I used below…..not sure if they are still available
    I have installed the halo passing lamps with the turn signal……..but I chose not to use the blinker portion of the passing lamps…..
      Do you happen to have a link to those passing lamps you bought? I'd be interested in reading up on them, thanks!
    • bbf
      bbf commented
      Did the ones you installed fit factory cans or did you have to get Harley cans?
    The hardest part will be getting all of the wires through that small hole. Might be best to run all new wiring from the headlight bucket. Be sure not to break the wire insulation at the turn to the passing light bucket, or you will create intermittent or possible direct dead electrical shorts.
    Also, you will need to add load resistors to prevent the turn signals from "Fast Flashing". The original turn signal flasher will not operate correctly and it needs to see a "load"
    Incandescent bulbs have a load resistance, LED's do not have load resistance
    2005 Silverado Midnight Star
    • bbf
      bbf commented
      Yeah I had to put resistors on my old Suzuki when I did led’s. Thanks for your input and feed back.
    So I did use the factory cans but the trim rings didn’t work so I ordered these and used the trim rims off of them……
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    theses are the lights that I bought and have been very happy with them……
      Thanks for those links. They sure don't make it very obvious there is an amber halo (or at least I think I found a hint of that) in addition to the white halo from the description. So I presume there are 4 wires to those passing lamps? Ground, fog lamp (bright white center), white halo, and amber halo?
    • Ahodge75
      Ahodge75 commented
      If I remember correctly yes…..like I said I didn’t want the Amber function so did nothing for it…..also the lights were not very good with directions if I recall correctly…..I did this 3 years ago originally…..
    I also did rewire my passing lamps after the original wires started shorting out. Not really that difficult but takes a bit to get the wires through the frame of the lamps…..I added extra covering around the points where the wires bend the most. Ended up using electrical tape then heat shrieked the taped area to give extra protection…..
    Started by coolalexrex, 1 hour ago
    Started by NCB, 1 week ago
    Started by Ahodge75, 13 hours ago
    Started by TheDukeOfYamaha, 18 hours ago
    Started by BloodMoney, 4 days ago
    Last Post BloodMoney
    Started by CanadaboyA, 19 hours ago
    Last Post CanadaboyA
    234 responses
    Last Post YamaDave
    Started by VinnieRSC, 1 day ago
    Last Post VinnieRSC
    Started by Shores, 3 days ago
    62 responses
    Started by Kevin Gibson, 2 days ago
    Last Post Kevin Gibson
    Started by Papi, 1 week ago
    Started by Cwjackson2021, 6 days ago
    Started by BlueRidgeSasquatch, 6 days ago
    Started by Texter, 1 day ago
    Last Post Texter
    by Texter
    Started by jimlun, 1 week ago
    Started by Neil, 4 days ago
