I recently changed my 03 Midnight tail light to LED. What big difference!
LED Taillight Upgrade
If I may ask.......Where did you get the LED light and is it a simple replacement without upgrades.......
Ok great. I went LED all around and the taillight was the only light I had issues with. I just replaced the bulb and it wouldn't stop flashing on me for some reason. So I went back to original bulb. I might have to upgrade to this set up. Thanks!
The Stop light circuit is separate from the turn signal circuit.
This applies for motorcycles and cars, unless you have a integrated combination stop light with turn signals.
Motorcycles and cars that originally used standard incandescent turn signal bulbs, have a turn signal flasher that is set up to be used with incandescent bulbs. Incandescent bulbs have a different resistance/inductance than LED's.
Old school knowledge is that if your incandescent turn signals flash fast, you have a bulb that is burnt out because the resistant/inductive load changed.
Since LED's have a low resistance and no inductance, our flashers flash fast, because the flasher thinks it has a burnt out bulb.
One cure is to add load resistors
or replace flasher unit with a electronic flasher, but you loose your auto cancel that is on our bikes
or you can modify the orginal flasher unit, by adding a resistor to a spot in the flasher.
I did the last option.
I found a how to on line, took it a little further by cutting the case and adding the resistor. I then repaired the case and installed.2005 Silverado Midnight Star
Started by brianmac, 2 days ago
1 hour ago
106 responses
by Bnag0
2 hours ago
Started by Mad Maj, 2 days ago
Started by dna9656, 5 hours ago
by dna9656
3 hours ago
Started by KFallsRider, 16 hours ago
by KFallsRider
6 hours ago
Started by dna9656, 1 day ago
by Ahodge75
7 hours ago
by Chromepony
9 hours ago
Started by Sykobox, 2 days ago
by Chromepony
9 hours ago
Started by KFallsRider, 2 days ago
by Chromepony
9 hours ago
Started by ElVispo, 01-25-2022, 07:34 AM
100 responses
by ElVispo
10 hours ago
by dna9656
11 hours ago
18 hours ago
122 responses
Started by 6door7r, 2 days ago
Started by Mad Maj, 2 weeks ago
by Mad Maj
Started by 6door7r, 6 days ago
by Chromepony
Started by Tykes_Place, 4 weeks ago
Started by p birk, 1 week ago
by Tcontrol
